offsets, subaru and 6 stud
cunno96
Post by cunno96 » Thu Apr 19, 2012 12:53 am
im no enginer but i think all the studs would brake befor the hub after all how many hubs have you seen brake on any car compared to studs breaking and unless you are totaly useless and use the wrong size drill bit or miss so many times that half the hub has been taken of it should not brake (dont forget im NOT AN ENGINER OR ACOUNTABLE FOR ANY OF YOUR MODS)
Post by El_Freddo » Thu Apr 19, 2012 11:31 am
Welcome to the forum cunno96.
An odd way for an introduction to the forum - and a very old thread dig, but a good one none the less!
I encourage you to post up in the "New Member's introductions" thread located in the Subaru Chat section of the forum ;)
B00sting
Post by B00sting » Sun Apr 22, 2012 8:38 pm
Since its being dug up.
People could always go custom hubs.
And FYI 15x6 superlites in 4x140 brumby pattern are 211ea per wheel.
-97 Landcruiser :D
Post by RSR 555 » Wed May 09, 2012 11:42 pm
cunno96 wrote:im no enginer but i think all the studs would brake befor the hub after all how many hubs have you seen brake on any car compared to studs breaking and unless you are totaly useless and use the wrong size drill bit or miss so many times that half the hub has been taken of it should not brake (dont forget im NOT AN ENGINER OR ACOUNTABLE FOR ANY OF YOUR MODS)
I'm sorry to say this but are all persons in SA taught how NOT to use commas and full stops??
Drilling the hubs is not hard and doesn't require engineering skills but what you have to have anderstanding of how the hub is made and the material it's made from. When (in this instance) Subaru engineer and manufacture the 4 stud hub, it is designed with extra strength around the stud holes. If you drill them in areas that don't, then it doesn't take much grey matter to work out what might happen. If you were to design your own hub made from a billet then you would have more weight behind your statement.
