Rims for a 91 brumby
Hi guys,
I've got a 91 brumby with stock standards steel rims and am looking for a set of white sunrasia ones secondhand. 1) are they easy to come across? and 2) if I find a 91 wagon with the ones I like at the wrieckers will they fit my ute?
Robbo
Robbo
You'll be lucky to find Sunraysia's second-hand (except through eBay), but generic "L" series 13" rims are pretty common. I know of a handful in wreckers here at the moment.
I would highly recommend 14" Pug's (from a 504) or similar for on-road use - the handling with standard 13" rims is horrible compared to 14", especially in the back-end through corners at speed
My local wreckers had some 14" pugs recently as well.
All MY and L are interchangable (well, except MY standard wheels won't fit on the front of L series due to clearance issues), so any L series or earlier will bolt straight up and shouldn't have an offset problem.
Dean.
Dean.
- Reg Brumbys
Another option is mabey a set of Speedy Desert Rats (they apparently fit straigh on the the Brumby 4 stud Pattern)
I saw some on ebay this morning
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... :IT&ih=005
