List of 4x140 PCD Wheels ...
- Bantum
Version Two ...
Ok - here is the Second edition ...
Subaru 4x140mm PCD Wheel Reference Guide - V2
Updated & made pretty for you all ...
Note : The image above is only a teaser of just the first page, you will have to down load it to see the rest ...
Ciao, Bantum ...
Ciao, Bantum ...
- Bantum
Offset ...
Thanks henpecked,
Re PM : Yep it was my intent to add the offsets to as many of the wheels on the list as I can, however I ran out of time / info for this edition, so it will have to wait until the next ( 3rd ) edition ...
If anyone does know of an offset info on any of the wheels in the list, be sure to post them here & I will attempt to add them to the guide later ...
Keep finding 'em wheels too ! ...
Regards, Bantum ...
Regards, Bantum ...
I think that some of the aftermarket wheels actually have different offsets within the same design. The speedy desert rats come to mind - some seem to have MY/brumby offset, some have the L offset.Bantum wrote:Thanks henpecked,
Regards, Bantum ...
Also as per the option sheet posted on this forum, it appears that here in Oz the 2 official optional factory 13" wheels offered for the MY/Brumby , ie standard pressed steel, optional sunraysia style steel rims and the optional alloy Mags actually had slightly different offsets even thought they were for the same vehicle.
I've also seen a variance in offset with some of the different sets apparently identical aftermarket JDM wheels on the yahoo japan site .
Accordingly I thought listing the standard Pug/subaru offset for particular models may be helpful. It certainly took me some time to find the L and MY factory offset figures.
- Silverbullet
Offset information would be a big bonus, if it is available. The 2 different 13" MY wheels that henpecked is talking about had an offset of +43 and +45 right? Just looking at wheels online this seems a very high number, most wheels not even available above +35 or so. Okay so stay with me here; Would it be right to say a +35 offset wheel on an MY would reduce the track width compared to a +45? bringing the wheels further inside the arches and possibly rubbing on brakes/stuff inside the wheel arch?
- Silverbullet
I believe that the MY had 3 factory wheels in OZSilverbullet wrote:Offset information would be a big bonus, if it is available. The 2 different 13" MY wheels that henpecked is talking about had an offset of +43 and +45 right? Just looking at wheels online this seems a very high number, most wheels not even available above +35 or so. Okay so stay with me here; Would it be right to say a +35 offset wheel on an MY would reduce the track width compared to a +45? bringing the wheels further inside the arches and possibly rubbing on brakes/stuff inside the wheel arch?
pressed steel at +42 and 4.5" wide
and the sunraysia and alloy sets both at +45 with 5" width
the two optional wider rims with greater positive offset essentially decreases the track (centre of tyres) by 6mm but only increases the track overall width ( outside of tyres) by only 6mm instead of the 12.5mm that a 0.5" increase in rim widths would have done if the offset had remained the same.
excessive hair splitting here - but if your having an argument in a pit inspection it may be usefull data.
- Bantum
13" Wagon Wheels ...
Thanks to Willy I can finally show the differences between all the different 13" Steel Wagon Wheel types to be found in OZ :
Sunrays : ( Also been called Sunnys or Sunraysias ) ( 13 x 5.5" +? )
Peco Star : ( 13 x 5" +? )
Subaru Gen 1 : ( EA 81 ) ( 13 x 5" +? )
Subaru Gen 2 : ( EA 82 ) ( 13 x 5" +? )
You'll note the slight differences between them all ... ( I'll come back to add more details here )
Note : & just to make things difficult - I know there's another one out there, just got to find it now ...
Cheers, Bantum ...
Edits : Will add more here also + will need to add Offset where I have a ? ...
April 2015 - revised links ( FB dicking around Again )
- The spoke 'hole' in each case is different,
- The spoke width varies,
- Curve of spoke is also changed ...
Cheers, Bantum ...
- Bantum
14" Wagon Wheels ...
& just to make sure you not confused yet, we also have these in 14" ...
Jacksons : ( 14 x 6" +? )
Speedy Desert Rats : ( 14 x 6" +? )
+ any others out there yet to be found ...
Note : When I mention the term 'Wagon Wheel' I'm referring to the number of spokes - usually 8 ...
Cheers, Bantum ...
Cheers, Bantum ...
- Willy Fisterbottom
Looking for one more 13x5.5 deep dish Sunraysia Like this so I have a complete set of 4, I found one today at a wreckers to make 3. Found another at another wreckers but it was 13x5 and different offset. The search continues.
The wrecking yard where I got the matching deep dish got it off an 84 touring wagon.
I currently have 3 different types of 13" Sunraysias. If I post them on FB can you put them here Bantum?
http://www.willyweather.com.au
Will do, just remembered the set on the Gen 1 Brumby is different again, so I have 5 different types.
- Bantum
Oooo ...
Found this weird one I've not seen before :
Found here : http://www.do-blog.jp/otaru-radiator/category/171
I'm not sure if it is 140 PCD, but it sure looks different ...
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
Scorpion Copy ...
And the new boy on the block - Thanks to Phil ...
Got a name for 'em yet ? ( Add : On closer inspection - I note they are stamped Brumby Wheels )
Left link to old FB photo in case someone is still looking for it ...
Brumby Wheels : 14 x 6", 950kg load rating, 93.1mm centre bore, 5mm thick centre, +55 offset ...
Add : They come in Black & White & will sell for $ 120 Each + P&H ...
See Phil for more details ...
Cheers, Bantum ...
Edit : This is 4th time I've had to reload this image - FB keep Changing the location ...
Edit : Have now upload it on Photobucket, as FB can get Stuffed ...
Cheers, Bantum ...
Those rims are from a Subaru Justy, certainly not a PCD of 140:Bantum wrote:Found this weird one I've not seen before :
Cheers, Bantum ...
Justy Brochure
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
