94 WRX to 97 N/A impreza
Im looking at buying new brakes/disks for my impreza
Ive found from from a 94 WRX, although i dont know if they are better/worse or what.
as my impreza has drums on the rear wheels, i was curious, does the WRX also have drums?
anything else i should know about brakes?
Thanks
Thanks
- d_generate
Front WRX brakes are 2 pot & all WRX's have rear discs, they will be better but I seriously doubt you'd notice the difference unless you were to track the car.
- sven '2'
Why upgrade?Avidus wrote:Im looking at buying new brakes/disks for my impreza
Thanks
New rotors, fresh brake fluid, and quality pads will be upgrade enough for the power of your car.
well since I just have a n/a impreza I dont see much point in having it perform like a track car.
The reason I was looking at WRX brakes is because they are cheaper than new ones, and the drums on my impreza look horrible.
I just want my car to look sexy, that way when I make a performance vehicle it wont just render this one redundant.
- d_generate
Front brakes will look exactly the same but will go straight on so if you'll save money grab them, I've got a set with rotors sitting here from a 94/5 also, it's only 99 onward that got the 4 pots which look totally different & would probably also mean a change of wheels.
Changing to discs at the back can be done but you need struts, different knuckles & all the backing plates etc, find the bits off an old Liberty, they are the same fit, much easier to find & cheaper.
- d_generate
Pretty much all the same from 89 to 98, just don't go any newer. Must use FWD knuckles & struts too.
