blow off sound in brumby
- brumby_pete
i put a $75 cannon on the brumby for shits and giggles and it sounds that good its not funny. really didnt expect it to sound so good. when im being a tosser and rev her right up and let off the throttle really quickly i get this blow off valve sorta sound. it only happens if i really rev her up though. ive looked around the engine bay to see if i could find anything and i found a valve thing inside the air box inside the section the oval filter encloses. i dont have any probs with it but i'd like to know why it does it. its only happened since i put on the cannon so i dont know. any ideas on what it is would be awesome.
Cheers.
Cheers.
So obviouslly you dont have an EA81Tbrumby_pete wrote: i found a valve thing inside the air box inside the section the oval filter encloses.
Cheers.
The valve is something to do with emissions, i doubt it would make the noise.
As said above, probably small backfiring in the exhaust
- Sti_Brumby
when i was putting my weber on my brumby i took all the emission contorl stuff of one by one, there is a vacume hose that gose to a valve caled an anti-backfire valve when you disconect one side of it and rev the car it would make a blow off sound, maybe one off these hoses have come off,
![Image](http://img230.imageshack.us/img230/2140/car2editej6.jpg)
its up around here...
84 MY Sportswagon
92 Brumby
87 Rx Turbo
92 Brumby
87 Rx Turbo
- brumby_pete
ok ive done some serious reving haha and its not that sort of sound at all. its more like a constant gush of air. it continues to have the gushing sound if i keep it around the redline area. i think i called it a BOV sound cause i only kept the revs that high for a moment. another thing ive noticed is when im in third and i slow down by going into second and just let the compression slow me down, particularly in second, i get that crackling quick popping noise and it does it heaps of times before it gets to low revs and it stops. that particular sound reminded me of an anti-lag system. a cop actually pulled me over yesterday to check if it was a turbo. (not allowed to drive turbos as im on the new P plate laws). what might these sounds be???Alex wrote:you need to put some resonators in your system. Is it like a crackling really quick popping noise?
cheers.
- Sti_Brumby
I get the same backfire and gush of air in my car but its an ea82, but i have done nothing to the exhaust. Ive always wondered wat it was.brumby_pete wrote:ok ive done some serious reving haha and its not that sort of sound at all. its more like a constant gush of air. it continues to have the gushing sound if i keep it around the redline area. i think i called it a BOV sound cause i only kept the revs that high for a moment. another thing ive noticed is when im in third and i slow down by going into second and just let the compression slow me down, particularly in second, i get that crackling quick popping noise and it does it heaps of times before it gets to low revs and it stops. that particular sound reminded me of an anti-lag system. a cop actually pulled me over yesterday to check if it was a turbo. (not allowed to drive turbos as im on the new P plate laws). what might these sounds be???
cheers.
simply because you said it does it at high revvs when downshifting makes me think you need a resonator for SURE! my car use to do it.
i'll go make a quick vid of my car now![Smile :)](./images/smilies/icon_smile.gif)
