I took to a spare Up-pipe with the grinder too see what was hiding under the heat shielding.
These photos will reveal more
Up-pipe is only 2/3rds the size of the crossover pipe
Obviously a restriction
Crush bend an already unsersized pipe
And my hands aren't all that big either
This is making the XtremeRX Up-pipe look very good, if only i could afford it.
I will try to modify it from the "T Interesction" up, that should improve things a little
I will admit, the pipe is well heat shielded, under the metal covers, is a 1/2 inch wad of heat resistant padding.
