ea82T
- stamp_licker
ea82T
ok got a ea82t into my wag what do i ask for exhaust wise at a exhaust shop.i thinking from the dump back at this stage .the missus drives this as a shopping trolley during the week so nothing to droning but a good note.at the moment you can't hear the car running. Cheers Will
Building a hardcore postie:D
I got 3" dump....its not that tight really..and the join underneath to exhaust/muffer section is in original position too..so using all original supports as intended too
the only drawback is the heat radiated to the inner CV boot, but I have found that wrapping the inner CV boot with the silver wine casket stuff and cable ties really works at keeping the life of the rubber..
I think the bend and weld close to the cat really tests the skill of the exhaust shop...if they are too inexperienced and lack the skill walk away and find someone else...because original is the best position IMHO
- tim_81coupe
- Fury
With a pleasent burble, and quiet enough for the Mrs to drive, and the blue boys not to take interest - a 3" mandrel bent, from turbo back, to twin 1/2 tips, cat under, and even on a Vortex, the hiflow cat is not much lower than anything else. - ... and yes, it goes off road, and tows boats along the beach, and....
Chris
'88 Vortex AWD turbo with "go hard" attitude -
WRX EJ20G and box , TD05 Turbo and 4.111 running gear.
5 Stud conversion (Crossbred Performance) Multi pot GT Legacy brakes and 17" rims
Plenty of plans... the plans are getting done slowly;).... getting there - NOT!
Noticable change in power with bigger exhaust?
How much difference does a larger exhaust really make to a ea82t engine anyway anyone dynotuned.
I got one on a rx about 7 years back and didn't really notice the difference driving it
