Help! Turbo bolt snapped
I was trying to remove my downpipe thisarvo to fix an exhaust leak near the mid muffler and as i was removing the bolts from the turbo that hold the downpipe on, one of them broke.
What do i do, i only have 2 bolts holding the turbo on (the other was cross threaded when i got it.
Please help
Please help
- discopotato03
Yeah, sheared is a better word to discribe it, "sheared while it was trying to undo it" and yes off the back of the turbine housing.
- discopotato03
Pain in the butt but it sounds like your going to have to pull turbo and get someone to remove the remains of the bolt . I think there's four bolts holding it to the up pipe , one for the brace and three to hold it on the flange . The oil feed pipe is a little fiddly but not as bad as some . From the turbo it runs down and under the turbo side head to another banjo bolt underneath this head .
None of this is unusual with turbos , they often have stainless steel fasteners and stainless threads have a bad habit of locking up . In the past I've had some success with high tensile steel bolts but possibly I was just lucky .
A .
A .
Pftttt they so easy to remove.
Drill out the bolt with a drill bit that is slightly smaller than the bolt.
Then use a Tap to re-thread the hole the same size as the original stud/bolt.
Then its fixed! I have done this to 5 or 6 turbos now.....
http://www.subiparts.com.au
0438 887 746
0438 887 746
Thats what im thinking.
But something crossed my mind, while i have the turbo off, why not put a
TF035 on there (xt forester turbo)
It doesnt take much to modify the up pipe and all i need is a wrx downpipe
Opinions?
Opinions?
Gannon,
You Have a PM
You Have a PM
0438 887 746
0438 887 746
