EA81 twin port Y pipe
phantomD
Post by phantomD » Tue Sep 24, 2013 10:29 pm
Hi all,
Firstly apologies for being absent on here for quite a while. I've just relocated state, changed job and 100 other things which are only just beginning to settle down.
I have an EA81 twin port engine in the final stages of rebuild, and my attention is now turned towards the fact that I have no Y-pipe for it to match the larger diameter outlet in the heads. Does anybody that has/has had one of these engines have any tips for finding or fabricating one?
I have an existing 2.5 inch exhaust system behind my standard EA81, this should be ample for the higher performance engine, correct?
Many thanks.
T.Farm.Brumby
Post by T.Farm.Brumby » Tue Sep 24, 2013 11:34 pm
Hi,
Haven't had experience with the twin port, but I have a 2.5" on my stock EA81 as well and it goes well. And my EJ22 RX Turbo has a 2.5" (I think) and it goes fine as well.
As far as fabrication goes, do you have headers? or is it just stock exhaust with no extractors?
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'89 Brumby "Brumbylicious"
'03 Outback "Uma"
'05 Forester
Post by Gannon » Wed Sep 25, 2013 6:03 am
I think L series headers are what you are after
Post by TOONGA » Wed Sep 25, 2013 6:48 am
The headers will need to be custom made as this is what I had to get done when I finally got my engine in all those years ago.
Post by Silverbullet » Wed Sep 25, 2013 6:09 pm
I have a factory twin port Y pipe although battered (only keeping it for a template) these should be the measurements you need. The only important part really is the two flanges that bolt up to the heads, everything else can be made to fit your car. The main hole in the middle isn't round, it's ovalled (see pic) and the large flange where the two pipes join together is 2.5" diameter, should fit your system nicely.
littlewhiteute
Post by littlewhiteute » Wed Sep 25, 2013 7:40 pm
Damian,
I'll check dimensions from the pics supplied.
2.5 inch will be more than ample although the note will be different, from cam compression etc.
Gary ;)
Post by Silverbullet » Wed Sep 25, 2013 8:36 pm
Oops should have said the distance between centres on the 2 stud holes is a bit wishy washy, the holes in mine weren't exactly round so it was hard to get an accurate measurement (somewhere around 85-87mm)
Matt
Post by Matt » Wed Sep 25, 2013 11:14 pm
I have 2.25" on mine and i love it, straight through pipes and mandrel bends, (One straight through muffler). It flows very nice, but it is apparently loud behind it, (don't know never been behind it). It is the exact size you need for the heads, but 2.5 " will do well. but i would put a hotdog or resonator in it, to quieten it down a bit..... But been the Brumby the tray stops most of it lol :)
"Claudia"
phantomD
Post by phantomD » Tue Oct 01, 2013 10:01 pm
Thank you all, that's amazing help!! Especially the pics!
Post by Bantum » Wed Oct 02, 2013 1:05 am
Here's a few more ...
showpost.php?p=203397&postcount=7
Cheers, Bantum ...
Return to “Intake & Exhausts”
