2002-2004 STi "diff back" muffler picks ?
discopotato03
2002-2004 STi "diff back" muffler pics ?
Post by discopotato03 » Wed Dec 03, 2008 12:50 am
Does anyone have pics of 2002 - 2004 WRX STi diff back or third section of the exhaust from the last joint to the tip in cap on forwards english ?
I need one of these for a L series RX Turbo and tried to post in the classified section - but no matter what I do it says I don't have permission to do so .
I have no time for template BS so if anyone has pics or one for sale please let me know .
Cheers A .
Matatak
Post by Matatak » Wed Dec 03, 2008 6:59 pm
mmm i can get you some pics of the last section of Exhaust from a WRX not sure on year but im thinking it was around 05 or 06 (currently not in a car)
if it helps it is almost identical to Early Libertys with a couple of different degree bends from memory trying to line it up in BrennyV's Liberty.
its also a huge muffler
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
gx_rex
Post by gx_rex » Wed Dec 03, 2008 9:54 pm
I have a diff back exhaust of an 04 STI foz on my GF8. Exactly the same length as the standard diff back on the GC8 just the centre hanger is in a different spot.
Dont know if that helps you at all.
discopotato03
Post by discopotato03 » Thu Dec 04, 2008 6:48 am
I'm told the ones to use are the early mid 90's STi rear muffler section .
It sounds like the middle section of the exhaust is the same on WRX's and STi's and that the rear muffler being ~ 2.25" on STi's is the only difference .
I still need to find out if the down/cat pipe is the same , I'm tempted to use an EJ turbo downpipe but I'm not sure if it's possible to check the condition of the Cat and new would be exy I'd think .
Cheers A .
discopotato03
Post by discopotato03 » Thu Dec 04, 2008 4:43 pm
From MS yep the only difference in each MY is the rear muffler section .
Cheers A .
discopotato03
Post by discopotato03 » Thu Dec 04, 2008 9:15 pm
STi rear muffler/pipe section in the bag and now to look for the std common WRX middle pipe to see what Subaru did with mid placed mufflers .
Also I need the mid pipe side of the swivel joint along with the bolts springs etc .
Once I have those we'll need to fabricate a down pipe using a spare EA82T dump flange and either a WRX or RS Lib swivel mount .
I do have a 3" Cat lying around and fingers crossed it will fit where the std one is ATM .
With a factory style 2.25" exhaust Ellie should be able to breathe a bit easier than she can through the butchered EA82T down pipe and pea shooter exhaust . I'm hoping it will be very quiet compared to some turbo'd Roos ...
The STi tip looks at least a hundred miles a hour faster than the current surface rusted 2" tube , all helps cheers A .
discopotato03
Post by discopotato03 » Fri Dec 26, 2008 6:57 pm
Bugger , 03 STi is too long . Can anyone tell me if the MY2000 STi one is more compact ?
Cheers A .
Return to “Exhausts”
