Anyone have a 2.5" exhaust on their EA82 ?
Howdy all,
I have an EA82 powered vortex (alas not the turbo). From what I have read in other postings it sounds like a 2" system is the largest recommended sensible exhaust size before low down torque is affected.
The rear muffler I have my heart set on has a 2.5" inlet and I would like to hear from anyone that has a 2.5" system on their ea82 re how badly low end torque etc is affected.
I assume that there's no point in having a 2" exhaust feeding into the 2.5" muffler?
I have the 2" going to a 2.5" muffler and I am very happy with it. Goes a helluva lot better than the old system. I found the bit of pipe that runs adjacent to the G/B was crushed to half of its diameter which was really giving me poo performance. When the new system went in(cat bac only though) it ran a lot better and has a nice note to it too.
Be careful with fitting a different muffler as there is naff-all space back there.
Do it I say - it will make a little bit of difference and will sound a bit better too without the droning of "silly" diameter systems.
Hooroo
Hooroo
Rob Forsyth
Cheers for the comments guys.
Sounds like installing a complete 2.5" system or going for the 2" system into the 2.5" muffler will both work.
I'd like the deepest wrx like note possible and prefer the idea of having the same size all the way through so reckon I'll go for the entire 2.5
Anyone have any comments on the best value exhaust joint in Adelaide?
Thanks again
Johnno
Thanks again
Johnno
few comments;
for suitability for your motor, note that an RS turbo with EJ20turbo motor runs 2.25" stock. my car with this motor runs 2.25" with a straight thru muffler. Any bigger than this will gain you nothing power wise on an EA82.
90% of how your exhaust sounds is down to your choice of rear muffler.
To get the famous and popular boxer rumble you need a turbo motor (the turbo headers make that sound happen).
i had a 2.5 with my ea82. Sounded pretty sweet hey. Dpends on the muffler and how many resonators etc you run.
Made bugger all difference to power. You THINK its faster cos it makes noise, but it isnt.
ahahaahah ......yer....
2.5 is as big as i would go on an 82...any bigger is a waste of time i think
dave
dave
- discopotato03
What Andrew said . You can make it really easy if you want by using an RS Turbos dump pipe though you will need to change the turbo end flange - maybe by using the one off your EA82 DP (have to increase the hole size in it slightly) . If you are interested in function size the exhaust around the predicted power output , 2.5" tube is plain silly for 125 Hp output .
I'm going to use 2.25" tube and this is plenty for 200 odd Hp .
A .
A .
Factory NA EA82 headers still produce the boxer rumble. They are just just as uneven the turbo headers, but probably flow better
Update..
Cheers for the comments fellas.
I went to D&T exhausts here in Adelaide yesterday and they said a 2.5" system is too large and will suck all power at lower and medium revs (and I don't have much to lose!!!).
They recommended a 2" or 2.25 system is the way to go for the exhaust & cat and then flare it out to connect to the 2.5" muffler (I want a Xforce Varex and the smallest is 2.5").
He reckons I'd get an extra 10 kws at the wheels with a free flowing exhaust and an extra 3 from a K&N filter. Does this sound plausible ?
- discopotato03
I think you'll find that Pipercross filters are better than K&N , I know everyone gets glooey over the washable aspect but try doing one because if it's not done VERY carefully they flow very poorly .
I think you need to rethink this 2.5" muffler business because it's not going to do what you want . The fact of the matter is that a 2.5" bore muffler on the end of a 2 or 2.25" pipe is a step backwards - regardless of what it looks like . If anything you want the tail end of an exhaust system to reduce in size because the gas loses a LOT of heat on the way through and when it does it contracts and loses speed or velocity . If it slows too much it can all but stop and thats when you get reversion issues that costs the bottom end torque .
The trouble with cars is that there are so many urban myths out there and people want to do inappropriate things and wonder why they get poor results .
I think I posted a link at this site before to Michael South Engineering (MSR ?) and how he gets best power and torque from a WRX in production rallying by going down in tube size towards the rear of his cars .
I'm not using The Force here , only the facts .
A .
A .
I went from the stock exhaust on my L series to a 2inch system done by Gepps Cross Exhausts. It made a big differeence to the way it revved and seem to have more go with better fuel economy. It had a straight through muffler and a newly fabricated headed into a 'Y' piece. It eventually annoying on long drives interstate so I fitted I hi-flow spots cat and a hot dog resinator. This gave it a nice exhaust note and made it a bit more quiet. I did notice some high end power lost though. The RX coupe has a 2.25 inch exhaust and this makes it go quite well and give the real WRX sound.
Cars: 02 Subaru Outback
85 Subaru RX Turbo Coupe (sold)
92 Subaru Brumby (sold)
- the gumbi brumby
- discopotato03
