EA82T Head to Turbo 'Power Pipe' Upgrade
- stamp_licker
WOW! The new pipe makes a HUGE difference!
It now pulls 4-5PSI @ 2000Rpm!!!!
The off boost torque is fantastic, it drives like it was running stock 13" rims...
40kms/hr in 4th pulling up a hill..........
Photos to follow....
http://www.subiparts.com.au
0438 887 746
0438 887 746
- discopotato03
Sorry.... I have been busy at work....
The pipe wasn't cheap around the $550.
It takes about 1 day to get built...
PM me if you want more details...
0438 887 746
0438 887 746
It was a little more than i wanted to spend but it is stainless steel with stainless steel flanges & its a dual fit pipe, it fits the early VF2/4 & the later VF8/10/12 etc. There has been a HUGE amount of design / fabrication work that went in to this pipe.....
Pics as soon as i can find my dam digital camera.....
0438 887 746
0438 887 746
There are no modifications required to fit. Unbolt the old pipe & bolt on the new pipe on - It’s that simple.
Unbolt dump pipe, unbolt turbo base bolts. Unbolt bolts of exhaust flange on head. Remove pipe. Installation is reverse procedure.
It’s not worth getting the pipe made in aluminized tube. It’s about $50 cheaper.
And the finish is not as good.
0438 887 746
0438 887 746
the engine crossmember would have to be dropped if you were fitting it with the engine in the car wouldnt it? i guess thats not really a problem though. How long did it take you to fit yours xtreme_rx? was the engine in the car?
timmo
timmo
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
GU Patrol Ute
Honda XR400R
you can drop the crossmember to get some more clearance.
I had it fitted by my exhaust fitter. it should be only about 1 Hr fit time...
0438 887 746
0438 887 746
- discopotato03
I am very interested... PM SentXtreme_RX wrote:Sorry.... PM me if you want more details...
Those who have sent me pm's I will respond to then as soon as I can I am snowed under with work.....
0438 887 746
0438 887 746
