think its too big
- SUBYDAZZ
I find that hard to believe, the amount of fuel added in the combustions cycle is negligible compared to the amount of air that is moving through the system. Having said that, the amount of energy required to squish a gas into a pipe is not very much either.Suparoo wrote:Probably to an extent.
There is a much larger volume coming out the exhaust compared to the air coming into the engine, this is due to the fact it has been mixed with a fuel and ignited, producing a hotter, less dense gas. That being said, a less dense gas also flows easier through a pipe because it creates less friction.
I think you'll find that the volume of air / gas / whatever is effectively exactly the same in and out. Give me details if I'm wrong here as I'd like to know.
SUBYDAZZ
Yes that is true, but that small amount of fuel ignites with the air, and its that rapid expansion of the air/fuel mix that pushes the piston and creates torque. That expanded air is pushed out of the cylinder the following stroke and down the exhaust pipe.SUBYDAZZ wrote:the amount of fuel added in the combustions cycle is negligible compared to the amount of air that is moving through the system.
- discopotato03
No , actually its the pressure in the exhausting cylinder that pushes the exhaust gas out of the cylinder . If the level of restriction in the exhaust tract makes the piston force the spent gas out it COSTS power and is known as "pumping losses" .Suparoo wrote:Yes that is true, but that small amount of fuel ignites with the air, and its that rapid expansion of the air/fuel mix that pushes the piston and creates torque. That expanded air is pushed out of the cylinder the following stroke and down the exhaust pipe.
The EA82T "header" is a good example of this .
