EJ P/Steering Rack into My's
Matatak
Post by Matatak » Sun Dec 16, 2007 11:11 pm
so ive been told that they are to wide/long compared to the MY racks..but is there any other differences..
ie. do they mount up fine??
im sure if they mount up then there will be a way to get around the fact they are to wide. with some mods to the Tie Rod Ends.
i havent looked under my MY that hard but ive got the rack outta my G1S2 Lib which id prefer to use.
yes i no that the Fittings are different also for pressure and return lines but that can be easily worked around in my case aswell.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
SuBaRiNo
Post by SuBaRiNo » Sun Dec 16, 2007 11:19 pm
I heard that the way to do it was to fit the tie rod ends off the MY onto the lib rack but you can't because the thread is backwards. Not sure if the same would apply for the inner tie rod ends.
Best way is... you got both sitting there.. why don't u give it a crack.
Dave
Matatak
Post by Matatak » Sun Dec 16, 2007 11:56 pm
but the Lib tie rod ends thread into the MY rack (which is what 90Brumby did - or is that only suitable for non p/Steering racks??)
yer i gotta do something neway..im now in the same boat alex was with P/Steering fluid dripping onto my headers cuasing nice smoke screens LOL
Matatak
Post by Matatak » Mon Dec 17, 2007 12:44 am
so ur sayint he Liberty outer tie rod ends are left hand threaded onto the Inner Rod end??
seems highly unlikely.
i no the MY ones are right hand thread as ive had mine off once before
aand the Lib inners are Right hand thread. i no that to (had some off to)
90Brumby is running Lib Tie rod ends on his Rack to (non p/steer tho)
the only issue i can see is the mounting wether it will or not.
Post by Subafury » Mon Dec 17, 2007 10:12 am
yeh go have a play- you have all the bits there matt.
Cam
Post by Cam » Mon Dec 17, 2007 1:28 pm
done it, just had to get the tie rod ends machined which i'm picking up this arvo. See how it all fits up then.
Matt
Post by Matt » Mon Dec 17, 2007 1:42 pm
You guys should live in Townsville, i can go visit George at Townsville CV and tell him i want a rack end, with whatever thread dimensions i want and he will find something that will work!!! And CV's too...
"Claudia"
Matatak
Post by Matatak » Thu Dec 20, 2007 11:45 pm
Cam wrote:done it, just had to get the tie rod ends machined which i'm picking up this arvo. See how it all fits up then.
hmmmm so did u use the Brumby crossmember or the one of ur donor Imp.?
and did it all end up fitting up?
how much u get machined off the tierods to? was it the inners or the outers aswell lol.
yer i kinda wanna no evrything :p
while im here
any1 no if their is a difference in MY crossmembers between P/s and non P/S aswell mainly in area around the rack?
SuBaRiNo
Post by SuBaRiNo » Fri Dec 21, 2007 8:10 pm
MY with power steering and non-power steering have the EXACT same engine crossmember. Made the mistake of thinking i had to swap them many years ago when i changes mine over.
Dave
Cam
Post by Cam » Fri Dec 21, 2007 9:01 pm
had to drill out the lower crossmember support thing, unbolts in ej's. Dunno what its called. had to enlarge the hole which the steering shaft goes through, solid mounted the new rack into position as the rubber didn't fit, bolted the lower xmember piece back up instead of welding. Waiting on the tie rod ends which will either consist of ej pieces which are threaded back and shortened or if there's not enough metal, my ones with thread inserted in and possibly helicoiled in the larger hole. Thing is they don't go back to work til the second so i wont find out til then.
Matatak
Post by Matatak » Sat Dec 22, 2007 1:50 pm
Cam wrote: had to enlarge the hole which the steering shaft goes through, solid mounted the new rack into position as the rubber didn't fit, bolted the lower xmember piece back up instead of welding. Waiting on the tie rod ends which will either consist of ej pieces which are threaded back and shortened or if there's not enough metal, my ones with thread inserted in and possibly helicoiled in the larger hole. Thing is they don't go back to work til the second so i wont find out til then.
Thanks Cam.
im pretty sure i know wt ur talking about with the
"had to drill out the lower crossmember support thing, unbolts in ej's. Dunno what its called."
the bit u normally jack up on (well i do neway)
on my wagon it has 2 bolts at th back but i cant see the front coz of the sumpguard bolting on and blocking that part.
guess ill find out soon enough neway
Matatak
Post by Matatak » Mon Feb 11, 2008 11:35 pm
so Cam. any more news?
has it worked for u.
much vibrations with Hard mounting it? etc etc.
PM sent neway
btw - for ne1 who cares. im not planning on the Liberty rack nemore (kindly gave that away to BrennyV). planning on using a WRX rack and pump (less turns lock to lock)
Post by AndrewT » Tue Feb 12, 2008 1:05 am
I learnt something about these racks yesterday - you can only really put them in an L or MY if you have a lift kit. If you put them side by side you will notice that the splined bit which goes into your steering extension is at quite a different angle.
If you have a 3" this is enough to soak up the extra angle but anything less and you start running into a dangerous situation (you would quickly get hard/soft spots in your steering and run a big risk of it binding up on you at a critical moment).
Cam
Post by Cam » Tue Feb 12, 2008 5:04 pm
Sorry forgot bout it, all done its fairly light steering but works well, the tie rods are the original impreza ones just shortened and threaded, was a pretty simple conversion... haven't noticed ne bumps or probs but haven't really driven it as iv got no exhaust and its a little loud...
I also put in the impreza steering column which with the 3 inch lift let me use the impreza's uni joint connector, no extension required...
PeeJay
Post by PeeJay » Tue Feb 12, 2008 5:08 pm
My brother had a WRX rack in his RX Turbo with no lift and it did bind while turning. I now have the same rack in my RX Turbo with 2" lift and it works great.
