Independant Headlight Relay Conversion
Posted: Sat Sep 22, 2007 10:16 pm
by Gannon
Some of you may well know that electrical current flowing through a wire causes a voltage drop. This voltage drop is caused by cable impedance and thus is directly proportional to cable length (and inversly proportional to cable CSA)
By the time the current travells from the battery to the dashboard and back to the lights, it must have lost a volt or 2.
So i figured i would shorten the length of my headlight cabling.
I used 2 relays (one for low beam and the other for high) and installed them behind the passenger side headlight.
I took a heavy gauge cable directly from the alternator output to the relays and then to the headlights. I havent tested the voltage at the globe, but i can tell you they are brighter and are a whiter light.
Pics and a diagram coming soon.
Posted: Sat Sep 22, 2007 11:35 pm
by 90brumby
sounds goood im lookin at doin sometin like this to the brumby was it difficult at all
Posted: Sun Sep 23, 2007 8:48 am
by Chris_Rogers
probably the reason liberty put them outside. did mine that way when I did the swap.
Posted: Sun Sep 30, 2007 12:27 am
by sven
with the upgraded wiring do not be tempted to go crazy with increased wattage globes.
I did the same in my old L, & put in 90/175 (or there abouts) globes...cannot remember the exact wattage but it was near 500W with driving lights on high beam
Light was good, but not that much better, for the hassle and expense and off road the globes would overheat and blow...very costly.
Only advice would some of thsoe 'white' globes by Philips...very good in the wet
Posted: Sun Sep 30, 2007 9:23 pm
by Suby Wan Kenobi
A while back i changed over the switching in Dads old MY, i used the biggest cable and the biggest relays and much to my delight the standard sealed beams gave off more light than my liberty lights. Did the same to my RX and the difference wasnt as noticeable
Posted: Mon Oct 01, 2007 1:46 am
Suby Wan Kenobi wrote:A while back i changed over the switching in Dads old MY, i used the biggest cable and the biggest relays and much to my delight the standard sealed beams gave off more light than my liberty lights. Did the same to my RX and the difference wasnt as noticeable
Great anti-climax there Subi Wan
Posted: Tue Oct 02, 2007 4:28 pm
by Ben
My Brumby's sealed beams are actually pretty good, I was quite surprised on my first night trip - will certainly be upgrading the wiring though when I get a chance to wire in the spotties.
Anyone know if I can get insert globe versions of the sealed beams?
Posted: Tue Oct 02, 2007 8:11 pm
by BaronVonChickenPants
Yes you can, from memory they're about $80 each without globes, been a whiles since I looked though.
Jordan.
Posted: Tue Oct 02, 2007 8:20 pm
by mattl200
the semi sealed beam inserts are the same as 80 series landcruser for the dual headlight brumby/wagon
if its dual headlight dont use the h1 inner replacements they short out on the body of the car and you have high beam all the time
unless you wire relays in at the same time
and you can get them for single headlight but not sure of a part number
Posted: Sat Apr 26, 2008 9:54 am
by Gannon
I thought i had already posted pics, but i'll try again
My new headlight loom
What i connected it to
I made it so if i wanted to revert back to factory wiring, i could just disconnect the bullet connectors and plug the headlight socket back into the factory wiring
Posted: Sun Mar 22, 2009 6:24 pm
by nncoolg
I did the semi-sealed conversion on my M.Y. wagon, i got them out of an old 180B, They are metal, not glass, and as mentioned above, short on the retainers, so need rewiring with a relay, they work good, and you can buy the nice big bulbs. I think the older M.Y.s with the single light could be replaced with the autobarn polycarbonite style semi-sealed lights from, like, a hilux. That would look cool.
