mounting radiator under bonnet?
Posted: Fri Jun 01, 2007 5:25 pm
just read another thread which gave me the idea of mounting the radiator on the underside of the bonnet. Im assuming it could only be pulled off with a large lift kit (possibly 4" minimum) to free up the space required. Would also need a large scoop and a couple of thin thermo's to suck the air in, and im also guessing the inlet of the scoop would make a difference, with the inlet faces forwards so it forces air in, or faces backwards, then the air would be coming in the front grill, and exiting throught the radiator. I cant decide which way would be better. facing forwards it would be forcing air into the engine bay from all directions, where as if it were facing backwards, there would be a smooth consistent flow of air from the front, over the engine and up throught the radiator. I Can see this working well at high speeds but for 4wd i think it would be worse coz with the thermo's going it would be sucking warm air from the engine bay.
im thinking this coz if i can remove the radiator from the front, i can fit in a flat 6 of some descrtiption, i also dont want to put the radiator in the back, so this sounds like my only option. With the correct plumbing and possibly a 12v water pump to aid pumping the water the extra distance, it sounds entirely possible.
so my questions are (and feel free to chip in wherever)
has it been done before?
is it possible?
should the scoop be facing forwards or backwards?
would it provide enough cooling?
minimum size lift kit?
am i stupid?
Cheers, Jay
is it possible?
am i stupid?
Cheers, Jay
