Leonie GL Sedan to Dual range 4WD ?
discopotato03
Post by discopotato03 » Thu Mar 22, 2007 1:41 pm
Hi , since RX Turbos are not readily available here ATM a couple of things I need to Know . Firstly is the L series sedan basically a 2WD RX-T with no turbo ? If so does the body have the rear mounts to fit the rear wheel drive and 4WD transmission ? I have been told that there was an L series 4WD sedan non turbo but not in Australia .
I have ideas about such a car with an NA EJ22 or 25 but need to know whats doable .
Cheers Adrian .
BrennyV
Post by BrennyV » Thu Mar 22, 2007 2:08 pm
hey mate, if ya pull up my leone 4wd thred you will see all the mods + pix on my webshots of howto convert FWD leone to 4wd ;)
Hunter S. Thompson
Rabbitoh
Post by Rabbitoh » Thu Mar 22, 2007 4:46 pm
There was , and they are still around, a 4WD Leonie Sedan, in Australia in the L series.
discopotato03
Post by discopotato03 » Thu Mar 22, 2007 5:05 pm
Thanks fellas , I could not find the 4WD Leone thread but did search - keen to see it though .
If available in Aus thats good news . Is it constant 4WD ?
Also is this the same body used for the RX turbo ie width length wheelbase ?
Thanks Adrian .
Chris_Rogers
Post by Chris_Rogers » Thu Mar 22, 2007 9:17 pm
its more common than the RX actually. its a PT4wd FT came out in japan and the USA.
I had a FT one in mine (jap wagon) before I took it out (sig)
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
