4 inch lift
4 inch lift
is there anything i should watch out for when fitting a 4inch lift to a ea81 brumby
cheers
cheers
- brumbyrunner
- stephendean
- cruzingbrumby
yer my old man made the block at work and the 2 missing bolts i found in our workshop ( head bolts out of some car we wrecked ages ago)
yer luckly its not the only form of transport cause im still on my L's
but im having some trouble with the 4 square blocks i think its slightly different to the one required for my car
but yer ill get there
Ok 4inch lift has now been fitted
in the proccess i have had to change the bottom hose, cut the side of the air cleaner to allow the top hose to not have a kink in it, dissconnect the 4x4 linkage to allow the gear selector to select gears (2, 4 and reverse)
bash plate needs to be remade to suit the 4 inch lift
eccesive camber on the front wheels
i think thats most of the thinks i have had to play with
ill post some pics up 2 morrow to show you all
- brumbyrunner
Yeah make sure the strut tops are pointing in the right direction at the top. Doesn't matter for L series but it does for MY.
Can't wait to see this Brumby!
- cruzingbrumby
oo the dual handbrake is popular hey tim:p
course i dont mind. its pretty easy to do - i just hope it works good enough for ya to b worth the mod- i didnt have time to test mine before i got welded diff. but meh still looks the part.
for the bash plate a few of us have got custom made ones of steel in varying thickness.
