So Saturday it was install time. When I really looked at it, it was totally different to the factory one. Not just in size but everything was different. Anyway with whitelines standard sway bar install instructions I was left to work it out myself. So after working it out it was time to go to the hardware store. Whiteline didn't even supply the nuts for the braket that holds the sway bar to it. After buying the nuts, washers, and some dom nuts (my choice) I went about putting it on. Well doing the last couple of nuts up I lookd at it and whet sh!t I forgot the rear shafts were not in. Bugger it had to move forward approx 60mm. So the next day it was time to go down to repco and buy some exhaust clamps. this is how it turned out.
This is a factory rear sway bar
Then the bits I had to buy, some are on the car already.
And then the left over bits. Thanks for the junk whiteline the dumb will thank you for them.
