another weber problem
Posted: Fri Feb 23, 2007 6:43 pm
hello all,i recently fitted a weber/holley 36/38 to my 87 brumbie. i have the usual problems with hesitation just off idle,etc but this is a new one..
If i drive like granny, as i do, I have no problems. But. at a rev range, say greater than about 60 to 70 km in third, the engine just cuts out, same pattern through all the gears. I am convinced it is not in the jetting, as planting the foot in third at a low speed,and opening the secondary, does not make it cut out till i reach the trouble spot in the rev range.I have had the jet size reduced from the largest possible, (140)which is how i bought it, to the next size down. The engine dies, then cuts back in, by which time i have reduced revs back to the safe range.
I suspect a problem with the acellarator pump, fuel bowl level, or some wierd little chamber within the carbie. Maybe someone has had a similar experience,
Thanks Tim
Thanks Tim
