3L H6 into an 'L'...????
L-Raiser
Post by L-Raiser » Wed Feb 21, 2007 6:56 pm
Does anyone know if this engine conversion can be done...??????
My mechanic tells me the engine is too big and would require too much modification of the engine bay.....
Can anyone verify this...?
Ive heard that some have managed to get a 6cyl into a Brumby or two....
Coz I managed to come accross a decent halfcut of a 2003 H6 Outback that I cant stop drooling over......
It would give me excellent low down torque which is what I want, would give me the same power as an EJ20 Turbo but without the 'turbo lag'....:D
Kaz
:rolleyes:
daza
Post by daza » Wed Feb 21, 2007 7:52 pm
Hey you could always try?
Putting one in a brumby means taking out the radiator and putting it somewhere else, and your L doesn't have a tray...
A Lib and a Brumby both done by Rising Sun Steve.
Daza.
:D
vidler
Post by vidler » Wed Feb 21, 2007 8:04 pm
ill help with any chassis mods you need if you go ahead
09 Forester XT Touring Wagon
tim_81coupe
Post by tim_81coupe » Wed Feb 21, 2007 8:45 pm
I think with the 6's it'd be radiator support beam mods more than chassis mods.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
L-Raiser
Post by L-Raiser » Wed Feb 21, 2007 9:08 pm
vidler wrote:ill help with any chassis mods you need if you go ahead
COOL....thanks for the offer....I may take you up on it...
Gotta make a few more enquiries yet with engine conversion experts....
It would be very exciting indeed if I could get away with it...!
The dream of duel pipes out the back with sports exhausts on the 6cyl mmmmm sounds hot just thinking about it...if it could sound anything like a Porsche six....YUM!
hehe
:-D
tim_81coupe
Post by tim_81coupe » Wed Feb 21, 2007 10:56 pm
Definitely.... matching the note of say a late 70's RS 2.7 Carrera would be sweet! Not sure how the 6's are for bottom end torque though, someone once told me they're a bit peaky for what they are. No doubt they'd pull more stumps than a 4 though.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Post by Gannon » Thu Feb 22, 2007 2:32 pm
I thought that the new EZ30 wasnt much bigger than the EJ20, something to do with its timing chains take up a lot less space than the timing belts of the EJ20.
You can get libs with either an EJ20 or a EZ30, there cant be that much difference
BrennyV
Post by BrennyV » Thu Feb 22, 2007 3:20 pm
Fitting in the radiator and getting one that will keep her cool enough maybe a little bit of a prob, but it sure would sound like sex on wheels :D
Hunter S. Thompson
seagull
Post by seagull » Thu Feb 22, 2007 8:40 pm
a 2.5 will out do the 3ltr off road & on road ( manual 2.5 )with 4.444 ratios
I have a H6 outback & the the power is on about 3300 rpm , its really laggy you have nothing than more than you know what to do with if you were off road .
The H6 needs a stalled box off road to get it up the hills or a dam long run up at the bottom , then your ground speed is like 70ks at the bottom with wheels spinning & **** in the air < in the car
IMO you will be wasting your time , 2.5 n/a with 4.444 ratios , then a WRX with a stock 4.11 auto > the 2.2 is getting old .I have one done 209000ks from a 97 liberty these after all these years still impress me
you can get a wrx auto cut low K JDM under $2800.00 + gst these have a Td04 turbo & come on low around 2000rpm they have a well built trans
Tims post is on the mark , then Jays as he is the man for cutting **** up & fissing the **** together
long live subaru , seagull
Post by AndrewT » Thu Feb 22, 2007 11:39 pm
I knew it...
What a co-incidence;
I just spent abit of time searching and finally found the thread from a little while ago.
showthread.php?t=4939&highlight=conversion
Unfortunately the website in there has been removed, but get this... it was all about some guy's L series wagon and he'd put a H6 Boxer into it. The spooky thing is it was bright yellow and had yellow colour coded bumpers and everything!
See in the post I even commented on it.
btw, from memory the car was driven very rarely on account of it always overheating - there is simply no room left in the engine bay for an adequate radiator.
Karen you may wish to contact Steve from Rising Sun Car Service in SA (he's also on this forum but best to give him a call at work). He's done a few H6 conversions. The most recent one he posted up on here is his son's Brumby (radiator located behind the cabin, in the tray).
showthread.php?t=4837
Steve's website is http://members.optusnet.com.au/risingsu ... efault.htm
L-Raiser
Post by L-Raiser » Fri Feb 23, 2007 8:46 am
AndrewT wrote: Karen you may wish to contact Steve from Rising Sun Car Service in SA (he's also on this forum but best to give him a call at work). He's done a few H6 conversions. The most recent one he posted up on here is his son's Brumby (radiator located behind the cabin, in the tray).
Cheers Andrew, I called Steve (Rising Sun) yesterday and he said they had a LOT of trouble getting it to fit. They had to resort to cutting the front engine bay radiator support bar to get it to fit, then put a radiator just behind the front grill. He told me that in SA they are in no way legal either.
I went to measure this engine and compare it to the EA82 and the EZ30 was only 8mm longer and 13mm wider than the EA82! I believe the EZ30 is a fair bit smaller than the older EG33 that he used too.
Ive since decided to can that idea....as it is making a lot more sense to get a half cut that I can utilise more spare parts from ie half cut 2.5L Liberty/Outback. :) Plus the EZ30 was an auto that would have needed a replacement flywheel & starter motor to bring it to manual spec....
Nahhhh my EJ25 is looking better now....hehe
Kaz
:rolleyes:
waggaclint
Post by waggaclint » Fri Feb 23, 2007 10:25 pm
if you end up getting a ej25 id suggest you get a sohc engine not a quadcam one....ive seen alot of engines and the sohc engine seem a lot better...get one from a forester would be the go..at some stage when i get around to a convertion on mine ill be looking for a forester motor.....thats just my opinion but hey im sure someone else will tell ya different....ive been a mechanic for 17yrs and ive seen alot of subaru stuff....the quadcam engines seem to have alot of cyl head problems (ie leaking oil and coolant..can get costly if something goes wrong)....you will pay more for a forester 2.5 but...
2011 Forester X
BaronVonChickenPants
Post by BaronVonChickenPants » Fri Feb 23, 2007 10:38 pm
Outbacks have the same SOHC EJ25 too.
Jordan.
waggaclint
Post by waggaclint » Fri Feb 23, 2007 10:45 pm
yeah they do some are quadcam but as well...i reckon your chances of getting a lower km motor would be better with a forester thats all...but yes outback is an option as well...
2011 Forester X
waggaclint
Post by waggaclint » Sat Feb 24, 2007 12:17 am
AndrewT wrote:I knew it...
This is the car Andrew was trying to find i think....
http://soobaru.hi5.com/
i think the guy that owns it might be a bit strange but hey....thats all i can say youl see what i mean....
2011 Forester X
Post by BaronVonChickenPants » Sat Feb 24, 2007 6:27 am
erm...yeah...just a bit strange Image
L-Raiser
Post by L-Raiser » Sat Feb 24, 2007 11:51 am
waggaclint wrote:This is the car Andrew was trying to find i think....
Ive just looked over his site and man...you're not wrong...this guy was OUT THERE....hehe 'Bit strange' is an understatement....he almost comes across as a born again religious fanatic....
But he is definately a Subi nut like all of us....which is good... :cool:
I like his choice in colour.... <wink>
When Ive finished my rebuild my car will look similar....if not better? ;)
Kaz
Ben
Post by Ben » Sat Feb 24, 2007 2:35 pm
I second what Seagull has to say. The H6 isn't the torque monster it should be.... Has hell grunt up top though....
And ask anyone who heard it on the sunday morning after the BBQ last year, with no muffling the thing sounds friggin awesome!!!!
Pity wifey wants me to keep it quiet, as it is most certainly porschesque in it's note.
Please watch before posting!
Loyale 2.7 Turbo
Post by Loyale 2.7 Turbo » Thu Nov 11, 2010 3:31 am
L-Raiser wrote:...But he is definately a Subi nut like all of us....which is good... :cool:
Kaz
Your Subie is Looking Good Too! :-D
Kind Regards.
d_generate
Post by d_generate » Thu Nov 11, 2010 3:22 pm
Does this car still exist? The thread was nearly 4 years ago.
