Vortex rear end to Leone (both 2WD)
Posted: Fri Feb 02, 2007 5:03 pm
by Rabbitoh
Has anyone put rear discs/rear end/arms from a 2WD vortex on a 2WD Leone only doing this for the disc brakes. Is it a straight swap. Any help appreciated. Thanks.
Posted: Fri Feb 02, 2007 5:10 pm
by Brumby Boy
Yea its a strait swap i believe. thre is a write up on it somewhere mabe on the USMB
Posted: Sat Feb 03, 2007 8:48 pm
by Chris_Rogers
straight swap. if you wish swap the entire rear.
Posted: Sun Feb 04, 2007 12:02 am
by coupe
If its a vortex to L series swap you can use the whole rear end its a better unit.
If its a vortex to leone (MY) then only the disks and hubs etc can be used.
Posted: Sun Feb 04, 2007 6:29 pm
by Rabbitoh
Sorry I Should clarify , its a 2 wheel drive vortex to a L series sedan (Leone)2WD.
Posted: Sun Feb 04, 2007 6:31 pm
by Rabbitoh
Without using the centre bar can the arms be removed front both sides along with the brakes/hubs and swapped over and refitted to my original centre bar.
