EA82T oil pressure gauge
wrx_nut
Post by wrx_nut » Wed Dec 27, 2006 9:05 am
got a mechanical oil pressure gauge for chrissy and just wondering where is the best place on an ea82t to hook it into....
its a mechanical gauge so needs oil feed from somewhere
cheers
wrx_nut
Xtreme_RX
Post by Xtreme_RX » Wed Dec 27, 2006 11:36 am
The front bung in the oil pump.
Watch out for the exhaust.
Use a metal line if you can.....
http://www.subiparts.com.au
0438 887 746
LTurbo
Post by LTurbo » Wed Dec 27, 2006 1:19 pm
Some RX's came with oil pressure gauge as standard (Jap models?). So when I installed mine I just found were the factory one should come from and installed it from there. Its at the front of the engine around the area near the oil filter I can't remember exactly were. It had a plug in it similare to the sump plug, pulled that out put the approriate fitting in and it worked sweet.
If you can exchage the mechanical pressure gauge for a electric one I probably would. I originally started of with a mechanical one but found the pipe to short, I also did not like the idea of oil coming inside the car. But thats just me;)
mattw
Post by mattw » Tue Jan 02, 2007 1:22 pm
yeah, mechanical gauges have a long history of burst/melted oil lines causing fires. my motor came with a pressure sensor for an electric guage, which fits in the larger plug hole, a switch for a warning light is in the small one. your fittings should fit one or the other. but that exhaust cross over pipe is "right there" to catch any oil drips........ I'd second L's recommendation, swap for an electric guage.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Jan 02, 2007 8:48 pm
I have a braided line running from the spot on the pump already mentioned to a gauge inside. Remember to fit the restrictor to stop the needle from bouncing.
The long road ahead
wrx_nut
Post by wrx_nut » Tue Jan 02, 2007 8:52 pm
yeah i got a mechanical one and i didnt like the look of the plastic oil line it came with.... do you guys have any pictures of the gauges and hoses etc you have on your subi's as it might point me in the right direction....
cheers
wrx_nut
