The next step
ORX-18
The next step
Post by ORX-18 » Sat Nov 04, 2006 8:24 am
Hopefully there is some info on the wrx gbox swap. if its at all dooable and cost effective enough it should be a set of 1-3 straight cuts and hard launches for me!!!!!!!!!!!!
Wheres the best place to get straight cuts from??? i tried mrt but they are pretty expensive, and practically laughed at me when i asked for them and explained what i was doing.
whats involved with the cv's and obviously tailshaft??
cheers guys.
TW83
Post by TW83 » Mon Nov 06, 2006 1:28 pm
What are you putting it in and what engine?. If you just want to put it behind an ea82 turbo that is probably why they laughed at you. Dont think you will be needing straight cut gears.
LTurbo
Post by LTurbo » Mon Nov 06, 2006 2:02 pm
TW83 wrote:What are you putting it in and what engine?. If you just want to put it behind an ea82 turbo that is probably why they laughed at you. Dont think you will be needing straight cut gears.
This ea82T makes about 260bhp and 420nm's of torque the last I heard, so if he is doing many launches some straight cut's won't go astray. The previous owner was going through L-series box's like nothing else.
ORX-18
beep beep
Post by ORX-18 » Mon Nov 06, 2006 3:22 pm
yeah, goes in for a retune and a more efficient turbo soon(ie. garret ball bearing) then hopefully it'll be good for some frightening 1.8 single cam power figures. Also, anybody know of some decent tire manufacturers that make a good race/road 185/50 or 60/65 13's??
cheers guys
Matt
Post by Matt » Mon Nov 06, 2006 5:14 pm
GT Radial do some directional Champiro GTX 185/65R13.. i have some on my ute seem pretty good, not that i have had a chance to give them a decent try. They are worth about $100 or so each.
Check them out here http://www.tyres4u.com.au/brandselector ... _show.aspx
"Claudia"
TW83
Post by TW83 » Tue Nov 07, 2006 1:50 pm
my bad. that sounds like an awesmone little ea82.
