Wheels of a different kind
Posted: Wed Nov 09, 2005 11:34 am
by BlackMale
Hey Crew sorry it been a while...
Though i would place this in here as i have finally unpacked (found) my aftermarket steering wheel (and boss)
Any other tricks to getting off a steering wheel?
I know that this should be a straight forward job however read on…
~ It WILL not just pull off (several attempts buy several non believers).
~ 3 finger pulley puller will not fit (have not tried 2 finger yet).
~ Bent 4mm mild steal on it as we thought that we should just be able to place it over the spline and then screw 2 bolds into the wheel thus drawing it off the spline = no success (hope this 1 makes sence).
Has anyone any other ideas?
I am seriously starting to thinking a trip east on some seriously corrugated WA roads with the nut off the spline, as it will rattel everthing else off :P
Posted: Wed Nov 09, 2005 11:49 am
by xaymaca
Possibly try a soft head mallot and smack it around the edge of the wheel to break it loose?
Posted: Wed Nov 09, 2005 12:16 pm
by vincentvega
make yourself a decent puller out of some heavier plate.
Posted: Wed Nov 09, 2005 12:17 pm
by Oversteer
Should be 2 bolt holes in the wheel/boss that are there to use a 2 bolt puller on.....
Even with a puller on there and tentioned up in some cases I`ve found you still have to smack the crap out of it(carefully of course !) to get the wheel to come free. But the puller is a must.
I have 2 pully pullers that fit...you can borrow one if your coming by this way.
Remember the gimpy hammer is your friend
OS
Posted: Wed Nov 09, 2005 12:35 pm
by Kev
As Oversteer said "remember the gympie hammer is your friend".
When you get some tension on with your home made puller, hit it hard with the gympie.
Make sure that the nut is protecting the thread or you could do some real damage.
On old mechanic friend once told me "If at first you don't succeed, use a bigger hammer".
Kev
Posted: Wed Nov 09, 2005 1:44 pm
by BlackMale
Thanks guys i should have added that Subg did smack with gimp friend and did not change the end result
O/S i might just take you up on that offer if we can get a time to hook up.
Bloody 5 second job take me a few days 8O glade she does not break to often
Posted: Wed Nov 09, 2005 1:54 pm
by Oversteer
I`m home, or not far from it all week... if your by this way ring and drop in
Justin - 0413943890
Posted: Wed Nov 09, 2005 7:22 pm
by stamp_licker
jaffa i have taken the wheel off many a time by just pounding with my fists on either side of it sort of like doing a drum roll.then it just pops loose wierd but hasn't failed me yet.
Posted: Wed Nov 09, 2005 7:28 pm
by tim_81coupe
You are undoing the nut first aren't you?
:P
I had to say that.
Posted: Thu Nov 10, 2005 12:17 am
by Xtreme_RX
Guys they do make a specific tool for this.
It's call a....... Steering wheel puller!!!!!
Repco / Supercheap / Kmart sell them, $12 is what i paid for mine.......
Posted: Thu Nov 10, 2005 11:02 am
by BlackMale
[quote="""]You are undoing the nut first aren't you?
quote]
DAG-NAM-IT!!! i had not though of that THANKS TIMMY.
Postie the drum roll thing could be an ooption but she has been smacked around a bit - how you feel anout a trip to my place to weave ya majic
Xtreme_RX we have tried pullers but no i did not know that there was a specific steering wheel puller, I'll see how i go.
O/S i think i can see you place from the feeway on my way home... not that i can see much at the speed i am doing. I drop you a line once i am home that way I can cruse over in the car… unless you would prefer I just grab and run.
Posted: Thu Nov 10, 2005 12:45 pm
by Ben
My puller was a piece of 8mm bar with two 8mm holes and a 14mm hole inbetween - worked a treat...
Posted: Sat Nov 19, 2005 12:35 pm
by wagonist
I've got one of the pullers from Supercheap.
It has always pulled off the hardest wheel.
Only value product in the whole store
