Power steering in ej conversion
Fittings for ej22 p/s pump (ANYBODY?)
Hey guys. Just wondering what the size and type of hose fitting is needed for the power steering pump on the ej22. Need to get some new pipes made up.
and
Which hose on the my is the high pressure hose?
and
I have the ea81 powersteering rack as it is a my touring wagon.
The ea81 lines are about 150mm to short with completely different fittings to the ej pump.
I need to know the type of fitting needed for the ej pump other wise I will have to take bugger around and take the pump out of the car to show them
what it is.
Anybody?
what it is.
Anybody?
I think is trying to say that if you use the EJ power steer lines, these should fit into the rack. Plus they'll boltup to the engine & its associated brackets, the pump.
Worse comes to worst, you might have to change the rack to an L series one (very common) & sell your MY version (probably nowhere near as common)
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
:???:Previous rides:
As far as i know complete custom lines will need to be made for the MY to EJ pump... I have them on my car... but im no fittings expert... i don't even know what they are called... I can't see how anyone will be able to help u unless u find a guy that works for ENZED that has done an ej conversion to an MY.
You might have to take the parts in there... As for putting the L series rack in goes.... i heard this is by far not a simple change over and over things other than the rack may need to be changed... im not 100% on this however.
Dave
Dave
Rack
I have just done the same conversion and ended up using a mix of both lines after getting the end of one of the pipes flared. Can't remember exactly but it all works. I do know I had to cut one of the brass lines. Drove my ej18 MY coupe for the first time last week. The L series rack will fit but you need to swap the rack end as the L series ones are longer. They use the same thread.
