RX Turbo box to MY
cameron
RX Turbo box to MY
Post by cameron » Mon Aug 28, 2006 8:45 pm
I am putting a RX box in my brumby and have not the time or energy to split a perfectly good box to change the output splines. Turbo boxes ran a 25 spline as compared to the normal 23 for most of the others. L series havn't the problem as you can get 25 spline inner joints (RX) but the brumby has shorter shafts and only one option. If anyone is thinking the same thing for there MY, PM or e-mail me on [email protected] and I'll tell you what you need. I will eventually be upgrading the brumby to the RX joints on my own shafts as they ran 19mm balls as compared to the standard 16mm. Even the EJ's have 16mm! If your resealing your box it is just easier to swap the output stubs while your at it.
If it can't be cut, welded or re-machined, you probably don't need it.
