EJ22 to EA82 Alternator wiring
robdddd
Post by robdddd » Sun Aug 13, 2006 3:35 pm
Help required wiring up the alternator from an EJ22 into an EA82 L series sports wagon.
The following is what I think I have worked out and would like some comments:
(A_A) EJ22 small Black/White wire connects to EA82 White/Red to the warning lamp on the dash
(B_B) Two large White EJ22 wires one from the plug and one from the bolt connection which connect together will get connected to the EA82 main wire heading to the fusible link.
(C_C) Single large white EJ22 wire from the bolt on connection connects to the EA82 Black/White wire heading to the fusible link (note, is it a concern that the EJ2 wire is much larger than the EA82?)
The Green and white wire I have no idea, does not show up on any wiring diagrams I have, the yellow wire from the diagram I have was on a 90-94 liberty only went to a diode and the ignition coil and then main fuse box (DON’T THINK I NEED TO CONNECT THESE?)
Thanks
rob
