Brumby Gearbox to 5 speed
Wooster
Post by Wooster » Sat Jun 20, 2015 1:32 pm
Guys, the answer is in all probability hidden in a thread somewhere, but.
Which 5 speed gearbox is the preferred option to transplant onto an EA 81, is an EA 82 5 speed a relatively easy transplant & if so what specifically does it entail?
I have access to a complete 97 wagon EA82 therefore all parts
Post by TOONGA » Sat Jun 20, 2015 2:29 pm
Wooster wrote:Guys, the answer is in all probability hidden in a thread somewhere, but.
here you go the hardest part is the tailshaft centre bearing mount points
showthread.php?t=11821
and a 97 "L" series would be pretty rare :) as they did stop making them in 1994 :)
Wooster
Post by Wooster » Sat Jun 20, 2015 2:51 pm
Ta mate, I'll need to check the compliance plate again, .......could be the eyes!
henpecked
Retaining MY D/R selector with L 5 speed G/Box
Post by henpecked » Sat Jun 20, 2015 3:01 pm
I bought a Brumby with this conversion, it had the 5 speed dual range selector inserted in place of the MY selector - which I did not like.
Silverbullet says he may have sorted out a way of retaining the MY selector with the 5 speed.
It clearlu has been done as here is a brumby for sale that has it ie a EA82 engine and gearbox with the MY dual range selector still in situ
http://www.gumtree.com.au/s-ad/south-ta ... 1080079319
Post by steptoe » Sat Jun 20, 2015 3:06 pm
is the 97 an 87 praps ? :) More importantly is it an efi ? The efi manual boxes had 25 spline stubs and a bit of a problem when it comes to mix n match to make Brumby CV shafts all fit up and work. If you have plenty of the readys it can be simpler to get a one piece tailshaft made up to avoid the centre bearing install. An L Series two piece is probably just a few mm longer than needed, so maybe if to mak a one piece measured on the 2 piece short by a few mm if at all, would be the guide.
