EDIS on EA81 MegaJolt :evil:
OK, Ratcamper started a thread on this concept a long while ago...long thread and no result shared
Anyone else care to share something like this:
http://www.autosportlabs.net/MegaJolt_Lite_Jr.
maybe this works
http://www.autosportlabs.com/product/megajolte/
link not work completely ??? takes to website, page not found
Ignition only so not an efi fuel requirement - do a carby or LPG fuelled EA81..
on an EA81 ? Who is gonna be the next one to tinker.
Sounds like Dougy has got some secret weapon under his bonnet along these lines ....
Looks affordable, tolerable, nice project if it all works up nice and programmable ignition mapping to suit current fuels
maybe this works
- Silverbullet
I was looking at something like this not long ago, after installing the Weber and having constant pinging problems. I was looking at the MSD unit though, nearly got one until I saw how physically huge the MSD one was and didn't know where you'd install it. Could be a very beneficial system I think, with every EA81 I've driven/owned the biggest let down is the ignition. Always going wrong, the advance system is crap, pinging, caps and rotors failing etc etc.
Looks like that one uses a trigger wheel (?) on the crank and a sensor. The MSD one uses the original points or electronic trigger in the dizzy to tell the brain box when to fire the coil.
Hmm, checked out their forum
This thing is taking shape on a wide range of vehicles.
http://www.autosportlabs.org/viewforum. ... &start=150
Looks like a spigot can be machined up or some other method to fit a trigger wheel to a crank pulley. Think I can see how peeps can get hooked on this concept.
Trigger wheels sell on ebay individually ....
Have you still got the ping issues Sam ? Now, I am curious as to what your cranking pressures are in the pinger.
I was stopped in a yard somewhereby a guy asking how old my Brumby was. Driving the middle aged one, could say had half the miles of the older one - only 410,000km. He knew of a fella near Cooma with 1.1 million on it same engine , extra head gasket
Wonder if yours pings at higher altitudes Sam ?
- Silverbullet
*Edit* I just wrote a whole bit about mounting a trigger wheel to the inside of the crank and Doug beats me to it with pics
Can you still run all the fan belts with that setup? I might go this way with my twin port, find somewhere hidden to mount the brains.
As for the pinging yes, it still pings if I stomp on it hard to get away, or WOT. Very frustrating as WOT is where my Weber sounds/pulls best
That is with the vac advance disconnected completely. If I run vac advance it pings when cruising at any speed/gear, timing seemed irrelevant and it didn't ping at WOT.
Also I don't think altitude was a factor, would do it down near sea level as much as up in the hills.
Corr blimey, that looks techo yet simple - thanks Doug - heaps. Now we need some followers to do the job first..where is Tweetys dad ? He's an adventurous one
What I'd love to see built in is coloured LED's that indicate all is good, or if no good, what bit needs swapping out .
Don't use all the glovebox space do you Sam?
That is where I planned to fit my 240V cappucino pump to run the fogger jets - four xmas's ago! Maybe 5 ???
Nah was taking too much of my time up. Thought Id try this out an am pretty impressed with it.
EJ engines are even easier. They have a 6/7 cam sensor from factory.
You can use MS to drive coils from the existing distributor. Just means you have to lock the mechanical and vacuum advance mechanism. If you planned on using the rotor cap and button still you would need to make sure it was fazed right or you could get arking to the wrong cylinder. Also not as accurate because the crank speed, particually at low rpms, isnt constant.
I went with the trigger wheel because Its neat and no moving parts. The timing accuracy is pretty awesome too. Looks like the flywheel aint even turning. Not even half a mm of jitter.
Doug
Doug
- TOONGA
I've heard good and bad about them not so good for injection but good / great for carby setups on motors without a dizzy.
widely available from the USA on Ebay
http://www.ebay.com.au/sch/i.html?_from ... rt&_sop=15
Got most of the gear from diyautotune.com
The audi VR sensor ive had for a few years kicking around, the 5.125" trigger ring was from ebay, the sensors like MAP and IAT were in a harley throttle body I picked up for 100bucks. I also have a freescale 3 bar MAP sensor Ive had for years which would work just as well.
Injection seems fine to me Jules. I had it screaming on the beach the other day and It held lambda better then the carby ever did. Idles better too. I havent completely tuned the VE map so its still rich, uses a few litres more fuel then before.
I did actually damage the ecu when I first installed it. It has a circuit to pick up crank signal from the coil like a std tacho does. This lasted about 5 seconds. Luckily Im a PCB tech, so I pulled it apart, found the failed part and replaced it with something a little bit more beefy (was a 680R 1206 package resistor, replaced with a 1/4w leaded resistor) and it held up just fine after that.
Jonno, Probably a little bit too much coin for a spark only setup. If you went to LPG injection......would be sweet as! Maybe keep an eye on ebay and one will pop up second hand for cheap.
Doug
Doug
showthread.php?t=18929&highlight=edis
don't bother with above link - goes way off then drops off.....
busy reading all this....is the EA81 not too crude to get an advantage out of the EDIS idea ?
- Silverbullet
Digging up an old thread, just to let Jonno know, there is a megajolt ECM, trigger wheel and a pile of Ford EDIS bits heading my way
So a year after your request you'll get a thread detailing how to convert an EA81 to distributor-less ignition and piss off the stock dizzy
Looks like it should be a relatively simple job to setup and run, once the trigger wheel is mounted. Biggest problem so far has been sourcing the bits; From what I've found there were no 4 cylinder Fords delivered to AU market with the required EDIS control module
Meaning having to source used parts from overseas which is pretty expensive. With that too if it ever goes kaput and leaves me stranded there's no wreckers yard in Australia that will have the bits I need
Might have to buy an extra module as a spare.
Watch this space
Watch this space
- Silverbullet
Probably something like this, as pictured earlier in this thread. It will require some investigation but hopefully I can have it on the back side of the pulley with the sensor and still clear all the belts. If I can't have the sensor as pictured, well then the dizzy will be gone anyway so there should be plenty of room to have it pointing at the side of the trigger wheel instead of straight down.
Subydoug wrote:![]()
No problems with belt clearances. You may need to sand down the engine casing so it doesnt rub. Also may have to be careful with position with the edis module, I dont know how sensitive they are to the missing tooth position. Mine could go pretty much anywhere so long as a TDC didnt correspond to the missing tooth gap.
Your other option SB is to make your toothed wheel fit inside the distributor. If you lock the distributor in the correct position you can still use the actual rotor and cap with a single coil for the stock look. Probably a touch more work then a trigger ring and batch fire coil and you will have slop in the distributor drive which will come out in the timing (not a problem at all, just wont be the pristine flywheel picture I get). If your keen to do the distributor method I have a spare dissy here Im happy to look into it and see if its even viable. It would need to have two missing teeth 180 degrees apart and it would be 72-2. Would also be a lot easier to get a cam signal for sequential injection.
Doug
Doug
- Silverbullet
Thanks for the post Doug! Haven't seen you around for a while
That's very good to know about the belts, I won't be able to test this for myself or mount up the sensor for some time yet. As for positioning, it says somewhere the missing tooth in relation to the sensor should be 90 deg before TDC on #1? or something like that, different for 4, 6 or 8 cyl engines. Shouldn't be too hard to set up, and I will try and build some adjustment into the mounting bracket if I can.
Thought about using the dizzy, I've got a couple lying around myself. But in the end I like this idea better
Maybe I'll have room then for an L series style P/S pump, although I doubt it with twin carbs sitting there. I'm not going for fuel injection at this stage. I've ordered a Megajolt controller (I think you were using megasquirt?) which will only control wasted spark timing.
Looking forward to using modern coil packs and no more rotor buttons.
I keep an eye out but dont bother boring everyone with my dribble.
Yeah Mine is 89 or 88 point something. I had to set it in the software but it was ages ago. Vast amounts of room with the distributor gone, can have a party under the airbox now...well maybe a small party. I went the coil pack to get rid of the rotor assembly too.
Im actually using a Microsquirt. Uses MS2 code so its basically a megasquirt. Its a bit of a shame the Megajolt is limited to using the ford EDIS stuff. Im sure its good though. Electronic ignition timing was pretty much the best thing I did to my car as far as performance goes.....well, the most sensible at least
. Now when I drive the vortex I feel like bashing my head against the steering wheel.
If you want some different shots of how the ring gear is mounted let me know. I need to pull the pulley off and check my oil pump isnt leaking anymore anyway.
Doug
Doug
