Easy temperature switch
Dad asked me to come up with a over temperature watchdog for a stationary diesel engine (irrigation pump) that would turn it off in the event of over temperature.
I was looking at these first for $150
Then these for $13
Then I saw one of these for $1.46
and it got me thinking... why does it need a display if its for a stationary un-manned engine?
So a little searching landed me with these for roughly the same price and they are available in both normally open and normally closed
I can crimp one in a 25mm2 cable crimp or fold aluminium or copper around it and bolt it to the head of the engine and then wire it to a horn relay in series with the ignition switch so the engine operates normally until the chosen temperature (you can choose almost any temperature between 40 and 200deg c in 5 deg steps) but once the temperature is reached, it opens, drops the relay out and kills the engine.
But a normally open one could easily control a radiator fan or an red light/alarm on the dash. Its cheap and should be foolproof and reliable.
Then these for $13
- vincentvega
I didnt mean I was gonna use the crimping pliers on it and crush it. Merely push it in and compress it just enough to hold it in place and then heatshrink it.
- vincentvega
No worries.
- Silverbullet
Silverbullet, I assume you are referring to thermal insulator not electrical? I'd say epoxy is a better heat conductor than air gaps. If you really wanted to be thorough you could use heatsink glue.
I was expecting steptoe to take interest in this thread. Where are you jono?
- Silverbullet
Yeah I meant thermal, only cause my train of thought leads me to comparing epoxy resin to plastic. Yes better than an air gap anyway.Gannon wrote:Silverbullet, I assume you are referring to thermal insulator not electrical? I'd say epoxy is a better heat conductor than air gaps. If you really wanted to be thorough you could use heatsink glue.
Yeah where is Jonno, usually jumps on this stuff
power down when I went to reply ??
Those self imported from HK , the sensor is a nice tight fit into a 4mm hole, no epoxy needed in my applications and they are working well. I have figured it is probably better utilised to switch fans on and off rather than an over temp alert as is how I have rigged them.
Another good find by Gannon
Crimp it, then fill the air gaps with thermal paste or even grease.
