EJ Auto fwd to auto AWD
stamp_licker
Post by stamp_licker » Mon May 15, 2006 7:33 pm
can the fwd auto loom and tcu be used when converting from fwd to awd auto?Is ther any difference between a fwd and a awd loom.Has anyone got a part no for AWD tcu?the loom/tcu in question is 91 series1 lib.
Thanks Will
Building a hardcore postie:D
stamp_licker
Post by stamp_licker » Sat May 20, 2006 9:32 pm
ok whats been discovered to date.the fwd auto loom is missing all wires assoiated with AWD however the plugs are the same The wiring colours are the same.So its just a matter of adding the pins and wires to suit Awd[5 or 6 wires].the tcu will plug str8 in.Thanks Dane for the wiring diagrams.
vincentvega
Post by vincentvega » Sun May 21, 2006 10:21 am
Sounds like you figured a fair bit out will ;)
Are you building an offroader? If so I reckon you should bite the bullet and fit a VTD auto box out of an early TT lib or early WRX. If your going to be going out and buying an AWD box and TCU, its not going to cost you much more to go VTD.
You should be able to pick up a TT TCU to drive the VTD for $50 but you will need to invert the throttle position signal as its inverted on the later cars.
If you can get an early WRX TCU you dont have to bother with the TPS problem as it matches the Gen1 style TPS. Problem is everyone knows this and therefore they cost about $400...
I have been thinking about knocking up a circuit to do the inversion as i will put VTD in mine when my box eventually dies, so i may be able to help you out getting a TT TCU to work.
Either way hte end result over a standard Gen1 box is way stronger rear drive which you really want offroad.
stamp_licker
Post by stamp_licker » Sun May 21, 2006 2:57 pm
Yeah Dane a offroader/tourer.Just collecting bits at this stage to do something i should of done 2 years ago.Just need the box,tcu and tailshaft a bit of time ,then i can play with the big boys. :wink:
simmo
Post by simmo » Sun May 21, 2006 6:07 pm
i will be selling a low km (46 000) auto gearbox from an rx impreza when i could be bothered to take it off the motor iff your interested...
