Hill Holder into Brumby
I have a 5 speed conversion lined up for my Brumby. The donor car had a hill holder which I took too. Has anyone put one into a brumby? It was sitting on the pax side chassis rail in the L series but the brumby A/c and heater valve hoses will interfere with it there, so it looks like it might need to sit under the master cylinder on the drivers side chassis rail.
If you've got one in your MY I would love to see some pictures. Cheers, Ron
- Brumby Kid
I've got one
It's called a handbrake
I'd like one too, and cruise control. Eventually.555Ron wrote:I have a 5 speed conversion lined up for my Brumby. The donor car had a hill holder which I took too. Has anyone put one into a brumby? It was sitting on the pax side chassis rail in the L series but the brumby A/c and heater valve hoses will interfere with it there, so it looks like it might need to sit under the master cylinder on the drivers side chassis rail.
I miss those features from my forester the most.
- Brumby Kid
Mudking reckons he can do it.
He said we will find one at a wreckers and then just put it in.
He sorta has a plan bit it will be do it as we go.
May or may not do it. It's a weird feeling, drive an old L and he said try it out.
Would an 08 liberty or an 02 STi have one?
As I said before, I use a handbrake.
Cheers Cam
Cheers Cam
- Silverbullet
Does that mean Dads L series has it, and the L series I junked? And every other bog standard manual L series putting around these days?? I never even knew that...well the one in our L doesn't work if it is theretaza wrote:Turbo's don't have it, auto's done. All manual non turbo subaru's have it from the L-Series(not sure about MY) up until the latest model Forester.
I love it in my Foz, use it all the time. It's the best thing to have in traffic.
Can someone give me a photo of an L-series AU domestic model Subaru with the hill holder installed. I remember the unit was mounted on the pax side - would like a picture of the master cylinder. Anyone know if the L series and Brumby vac booster units are interchangeable?
I have the RX brakes on the back so I am considering a swap over to a complete L series setup... Or maybe shelving the idea but that sounds too easy. And I did really love it on my old L series.
