mpfi to ea82t question.
Posted: Fri May 12, 2006 4:18 pm
by subelover
hi all, got a 89 mpfi touring wagon quick question, hope it hasnt been ask 2 many times... looking to fit an ea82 turbo motor and am wondering bout the harness difference? plug and play? any soldering? hopefully just grab the turbo cross member.. any info be fantastic get it all sorted b4 i buy a motor put it in and run into the problems. cheers
Posted: Fri May 12, 2006 8:01 pm
by AndrewT
Mostly plug and play. I beleive you can even use the MPFI N/A ECU.
Posted: Fri May 12, 2006 11:02 pm
by Gannon
Im in the process of doing it and was making good progress (damn headgaskets)
I have an 89 touring wagon and am putting a vortex ea82 into it
I had it running with the na ecu, i need to hook up the wgds (wastegate duty solenoid) to get the turbo ecu to work
The wiring harness between the turbo and na ecu is almost identical (for the 4 plug ecu) except for the knock sensor and the wgds, they are easy to add in.
Posted: Sat May 13, 2006 5:23 pm
by subelover
plug and play sounds fantastic just gotta find a good con motor now. spose it wint matter mite refreshen it.. cheers
Posted: Sat May 13, 2006 6:01 pm
by Gannon
Another thing,..
If you have a 89 MPFI loom, you will need a ea82t motor that came from a car built after mid 1987, also known as 4 plug ecu or the hotwire style MAF (mass air flow) .
Turbo motors built between 1984 and july 1987 were the 3 plug, flapper style maf and are not compatable with your mpfi wiring system
Any qtns, feel free to ask
