how a turbocharger is made youtube
Posted: Wed Sep 12, 2012 8:19 am
fastest 5:01 youtube I have seen, where'd the time go ?
http://www.youtube.com/watch?v=0oXMH9sp ... re=related
Posted: Wed Sep 12, 2012 9:08 am
by stilson
Very interesting.
Posted: Wed Sep 12, 2012 9:55 am
by TOONGA
Yep rather interesting... but the did leave out a couple of the processes before the final casting was done, and quite a few of the cleaning processes after the casting. so at 5 minutes it was rather brief. :)
Posted: Wed Sep 12, 2012 9:57 am
by RSR 555
Old technology but does give the good basic ideas of a turbo
Posted: Wed Sep 12, 2012 11:25 am
by discopotato03
Turbonetics makes (casts) a variety of their housings but much of it is dated Garrett technology they've bought the rights to .
Assembling a turbocharger from new clean parts is not that difficult , particularly a bush bearing one . Provided there are no manufacturing defects the hardest hands on part is manipulating circlip pliers and torquing up the compressors jamb nut without bending the turbine shaft . Basically you stand the cartridge vertically in a jig that has a socket into which the turbines outer side hex or double hex is . It has another socket driven by a supported T bar to spin the nut up . Experienced hands can get the torque nearly perfect but check with a special torque wrench anyway . Balancing is as they showed you .
Garretts BB cartridges are even easier as you have no bushes circlips or the thrust collar and plate to fit . Merely slip the bearing pack into the center housing and the oil inlet ferrule locates in the outer shell of the bearing pack anchoring it in the bearing housing/center section .
The saddest part about rebuilding a turbos center is that the piston ring that seals exhaust gas out often chops the turbine groove and center housings register out . So if your up for a new turbine and center housing often you may as well just buy a new cartridge and fit your existing housings onto it . This is usually the cheapest fastest option provided your cartridge is available . It was the reason why Garrett was reluctand to rebuild ball bearing cartridges but they do nowdays where possible .
A .
