Car smells of gasoline...
Posted: Tue Apr 25, 2006 11:42 pm
by vladrulli
ok, finished my ej20t conversion a couple of months ago... there was a gasoline smell inside the car after I've had in the shop for a couple of months and I thought it would clear out when I would start using the car... but the smell is not giong away! what can be causing this? I'm running a rubber fuel return line through the inside of the car - can that be the cause of it? or is this the charcoal canister bugging me?
Posted: Wed Apr 26, 2006 6:49 am
by Craigus
Have you hooked up the tank vacuum line?
Posted: Sat Apr 29, 2006 8:09 pm
by Lapsed
Shouldn't the fuel lines be run externally. Have you tightened all the joints?
chris
Posted: Sun Apr 30, 2006 9:04 pm
by fredsub
is the charcoal canister inside the car too?
how cheap is your life?
Posted: Sun Apr 30, 2006 9:20 pm
by Suba
8O I don't believe that to be a good idea either, so easy to just use metal lines they wouldn't get pierced like rubber could, and if you happened to get a bad batch of fuel hose it could deteriate and you wouldnt see it .
Mike.
Posted: Tue May 02, 2006 12:07 am
by vladrulli
hehe... what's wrong with you people?! the fuel lines run inside the car from the factory anyways - metal or rubber - what's the difference?! :P
I found the cause of the smell... my surge tank has a small leak and it's located near the heater duct openings and so the smell got inside the car through ari ducts...
Posted: Tue May 02, 2006 12:34 am
by tim_81coupe
My mate runs rubber 1/2" lines in his smallblock HJ, and has done for the past couple of years.
Personally I'd run steel lines, but definitely in the cabin. Any wire or pipe that runs from the front of the car to the back should be in the cabin IMHO.
