Hi guys,
I've swapped over long motors before from the gen2 ej22 to the gen1 ej22 or even swapped a ej18 in an impreza with a ej16.
When i say swap i separate the top manifold from the engine and bolt it on the other good one so everything can still plug in and work.
I'm wandering if anyone knows if i can do the same with a 99 ej20 off a forester, Bolt on the 92 gen1 lib top manifold for it to work?
Thx
Will a ej20 long motor fit in a 92 Liberty
- d_generate
Have a look at the bolts that hold the manifold to the heads, you'll more than likely find they are offset whereas the pre-99 are in a straight line so old manifold won't fit 99> 8 bolt motor without swapping heads.
Noooooooooooooooooooooooooooooooooooooooooooooo!!!!!!
