Ac - urgent
Ac - urgent
I Have a 91 model brumby and was thinking before the conversion takes place i will drive it round for abit.
In the mean time it doesn't have AC. I read some threads on what i need but is their any place that sells these or does anyone here have the bolt ons for what i need to get it running?
Thanks!
Thanks!
I've done this for 6 years now... Just need to get the spare dosh together to get the AC pipes made up and then have the gas conversion done on it and it should be apples, and cold.sven '2' wrote:Buy a fan, sweat it out, and dream of EJ goodness.
It's up to you as to what it's worth to you being cool in summer as you'll have to de-gas the system to do the conversion to the EJ compressor
The other way around it would be to work out how to use the EJ compressor on the EA81 with the flat belt. It could be a head ^&*^ but it would save on having to re-gas it again...
- Brumby Kid
Bennie,
When i take out my engine,
do i have to degas my a/c system?
Cheers Cam
Cheers Cam
- Brumby Kid
So if i kept the system as one, it would be ok?alang wrote:only if you undo the hoses or brake the loop
Is it a big deel de gassing and re gassing?
shift the jack out along with the charcoal cannister, place some anti scratch material like a rag down, get some rope ready then swing the compressor aside into the corner and tie it in place on the flexibility of the hoses, may need to undo a few AC line to body clamp brackets to give more flex, tie it down until reassemble.
If you're planning on doing an EJ conversion, you're still going to need a complete EA kit anyway because when you do the EJ conversion, you'll just replace the compressor and associated engine parts.
I'd suggest you have a look around for a MY Touring or Sports Wagon or MY Coupe from around 1980 through to 1984.
- Brumby Kid
You will need a dash with a/c wont you?
Im with the others, do it with the ej in it.
If your needing to swap the dash over to one with a/c vents. Do it with the conversion as it will need to come out for the conversion anyway.
My 2c Cam
My 2c Cam
- TOONGA
No the dash is exactly the same the only difference is the AC button.Brumby Kid wrote:You will need a dash with a/c wont you?
My 2c Cam
- Brumby Kid
Really? What about the vents for the air to come out of?TOONGA wrote:No the dash is exactly the same the only difference is the AC button.
- TOONGA
exactly the same vents as the ones used for the heater.Brumby Kid wrote:Really? What about the vents for the air to come out of?
If you have a look at this thread you will see how it is done.
- Brumby Kid
Ahh, thats why I have seen brumby's without, they probebly wouldn't have had a heater either.TOONGA wrote:exactly the same vents as the ones used for the heater.
- TOONGA
all brumbys came with a heater from factory, some were actually fitted with power steering (factory) and aircon as well (aftermarket through the car dealer)Brumby Kid wrote:Ahh, thats why I have seen brumby's without, they probebly wouldn't have had a heater either.
Im still looking for a picture (there is one on the board somewhere) of the aircon button installed on the brumby dash.
Ah, I thought the AC gear was already in the brumby and it just needed gassing, then the conversion (EJ) comes along and what you you do for that?RSR 555 wrote:If you're planning on doing an EJ conversion, you're still going to need a complete EA kit anyway because when you do the EJ conversion, you'll just replace the compressor and associated engine parts.
So that's where I was looking from!
- Brumby Kid
Well i have seen brumby's without the vents at all, (in real life too).
So that is strange.
Hmmm
So that is strange.
Hmmm
Here you goTOONGA wrote:all brumbys came with a heater from factory, some were actually fitted with power steering (factory) and aircon as well (aftermarket through the car dealer)
Giles.
Giles.
