Custom axles
Posted: Thu Aug 18, 2011 12:16 pm
Well I have hit my first dilemna in my Brumby build. I had planned to mount the complete Liberty suspension and crossmembers under the Brumby which I have heard of being done before. The rear end is easy and requires miniaml work but the front end is a tad more difficult.
Basically the bolt holes for the front crossmember line up with the outside edge of the chassis rail - if they were 10mm either side it would be fine but right on the edge - bugga !!
But that isn't my main dilemna - the worse part is the rear mounting for the lower control arms is right smack bang where the chassis rail is at the bottom of the firewall - fark fark fark - as the Australian Ravenb would say !!
Now it is possible to cut the chassis rail and make mounts up for the LCA and I'm sure you could make it as strongor even stronger than standard, but my engineer would have a coronary to see the chassis modified like that.
So there are 3 solutions :
1. Scrap the idea and just use the Brumby gear and uprate the brakes. Makes things easy but isn't what I want.
2. Lower the crossmember so that the LCA mount is underneath the chassis rail rather than in it. This will raise the car and make it look like a 4WD and is definitely not what I want.
3. Use the Brumby crossmember and Liberty everything else. This will bring the LCA mount inside the chassis rail and make it an easy job. Other benefits are that the strut towers won't need to be moved further out and will make the car really low. Which is exactly what I want. But this will mean that my front track will be Brumbyish but my rear track will be Liberty sized and will require flaring the guards by about 40mm which may look silly without flared front guards. The rear end can be shortened easily enough by cutting the control arms. However this will mean I need shorter axles front and rear.
So what I want to know is where can I get custom axles made up to fit ?
Or is there any chance that I can use Brumby axles with Liberty CV's etc ?
I have a choice of 2 gearboxes and diffs - a standard Gen 2 Liberty 5 speed and R160 and a V5 STi RA DCCD box and 1.5way plated LSD - will either of these make it easier to source a compatible axle ?
