Walbro fuel pump
Walbro fuel pump
Post by guyph_01 » Sun Jul 31, 2011 11:46 pm
Hi,
I have recently bought a walbro fuel pump for my Ej25 L series. It was more of an impulse buy Lol. Anyway, I have two main questions.
If its an in tank one, would i be able to use it for external purposes?
After reading on forums i realised that China made some very very similar copies of them that were hard to detect. Is mine a china copy? how can i tell?
As you can see its got that in tank filter thing:(
I'm asking as i rather loose a few $$ than lean out the motor, should the pump fail at any point.
Lol.
Thx
Post by El_Freddo » Mon Aug 01, 2011 12:28 am
Yeah I'm not sure about that in-tank filter! Usually you have a little cone like filter that fits in side the intake end of the pump.
By looking at that it is an external pump - the instructions should have some better details of where it fits but my best is an external pump, having wiring that you need to wire in is a give a-way to me. If it's an in tank pump that's just plain dangerous!
shuffbag
Post by shuffbag » Mon Aug 01, 2011 9:34 pm
looking at your pic i would say it is a in tank pump. the way the instructions show to mount it.
im unsure about external mounting.... how ever saying that me and my mates rigged up a in'tank pump/tub of fuel and a mate holding the pump to start a sr20det on the floor. so it will work :) not sure if it will cause a problem, but it will work
H-top
Post by H-top » Mon Aug 01, 2011 9:55 pm
Its an intank pump. cannot be used for external.....at all... but u should sell it on a Liberty or Impreza site to get some quick sale action :D
Get an external walbro. my outright favourite for size, weight and noise and they net plenty of pressure and flow.
Cheers mate
H-Top
rolling in
Post by RSR 555 » Mon Aug 01, 2011 10:10 pm
Yep, like H-Top has mentioned, it's an internal pump and due to the relief valve on them, it can NOT be used externally. I would chuck it up on P-WRX and buy an external one :)
Post by guyph_01 » Mon Aug 01, 2011 10:15 pm
Post by El_Freddo » Mon Aug 01, 2011 10:48 pm
Well there you go. I stand corrected!
niterida
Post by niterida » Mon Aug 01, 2011 10:57 pm
El_Freddo wrote:Well there you go. I stand corrected!
I find it a lot more comfortable to sit down while I type ......
Post by AndrewT » Mon Aug 01, 2011 11:57 pm
lol @ impulse buy. I did the same thing like 8 years ago.
Then I realised it was a silly idea anyway because even an EJ20 turbo engine runs fine from a totally stock standard touring wagon pump.
If you are still intent on upgrading the standard pump, get a VL turbo (bosche) external pump, but it's completely unnecessary unless there is something wrong with the standard one in your car.
Post by Alex » Tue Aug 02, 2011 11:13 am
AndrewT wrote:lol @ impulse buy. I did the same thing like 8 years ago.
absolutely.
the above mentioned pump is proabably the best for your application. I ran one on mt ej22s and then on my ej20g.
Post by RSR 555 » Sat Aug 06, 2011 7:59 pm
Yep.. go the Bosch 0 580 254 044 pump as it can handle a 6.6ltr holden without any trouble and you should be able to buy them for around the $200 mark.
