custom bash plates?
Luke82
custom bash plates?
Post by Luke82 » Tue Jun 14, 2011 10:51 pm
can anyone tell me where i can get a bash plate made up for the front of my L in the perth area?
Post by AndrewT » Tue Jun 14, 2011 11:04 pm
In your garage at home with some bit of metal you found somewhere is the best bet.
(Unless you want to pay more than your car is worth). :)
I good basis is a standard factory L series bash plate - modify it if needed.
Luke82
Post by Luke82 » Tue Jun 14, 2011 11:16 pm
cheers m8 i was hoping to be lazy and jst buy one but not if its gonna be that much :(
Post by El_Freddo » Wed Jun 15, 2011 2:44 pm
Lifted with the stock EA82? 2 inch lift: cut slots to the holes that mount under the engine crossmember. Then get a half inch wide piece of plate steel and weld it across the back end of the bash plate. This should allow you to bolt up the factory bash plate to the lift L series.
If you've got an EJ its another story as the sump is deeper... Here's a pic of my modified factory bash plate to fit around the EJ sump. Not the greatest as this pic wasn't taken for the bash plate :rolleyes: Same principle though, just more work involved with cutting and bending in the centre to get around the sump safely. The rear mounts are extended out about 1 or 2 inches with the use of some scrap box section I found. Anyway, here's the pic:
I would like to also cover the exhaust on each side of the engine but this will have to come later when I work something out... and find some time!
Post by Alex » Wed Jun 15, 2011 2:53 pm
mine on wanky wagon
Luke82
Post by Luke82 » Wed Jun 15, 2011 4:45 pm
cheers bennie no ej yet... alex thats exactly the kind of bash plate im after thanx also what type of tyres are you running and where did you get them from?
Post by El_Freddo » Wed Jun 15, 2011 5:38 pm
If you're after a bash plate like Alex's one above I'd wait until you have the EJ in, otherwise you'll be modifying the one for the EA - unless you have it made up for a mate's lifted L with an EJ already installed, that way you'll know it clears the sump and extractors of the EJ once you drop it in. You should get on to that as well, the EJ is a great upgrade to the L series!
Luke82 wrote:what type of tyres are you running and where did you get them from?
I think they were wild conqueror super trippers, but I think they're no longer in production :( They're a great tyre!
Post by guyph_01 » Wed Jun 15, 2011 7:02 pm
Few pics of mine.
Made from 9mm alu plate
yarney
Post by yarney » Wed Jun 15, 2011 7:29 pm
Luke82 wrote:cheers bennie no ej yet... alex thats exactly the kind of bash plate im after thanx also what type of tyres are you running and where did you get them from?
Both are running Nankang Super trippers a good tyre but not available any more :mad:
Jan
Luke82
Post by Luke82 » Wed Jun 15, 2011 7:40 pm
yeh ive been on the hunt for a donor car so i can start the conversion really really want one in my L. u mite be rite ill jst wait till i got the bigger engine and make one like the beasty one on guys kar, love that car .
Post by guyph_01 » Wed Jun 15, 2011 7:44 pm
Thx mate:)
Soon to be re-born:p
Luke82
Post by Luke82 » Wed Jun 15, 2011 7:49 pm
is there a similar tyre that anyone can suggest
Post by El_Freddo » Thu Jun 16, 2011 10:56 am
guyph_01 wrote:Image
^ because 27's and three inches of lift is never enough!
You could try out kumono (?) or Maxxis I think have a good tyre for the 14 inch rim and 27 inch diametre ;)
