2wd to 4WD
Lapsed
2wd to 4WD
Post by Lapsed » Mon Apr 10, 2006 7:00 pm
What is needed to turn a 86 leone 2wd in to a 4wd? how hard is it to do?
Chris
Post by AndrewT » Mon Apr 10, 2006 7:20 pm
Very easy.
You need the following...
1 x 4x4 gearbox (5spd dual range should be easy to find)
1 x tailshaft
1 x complete rear end from any L series 4x4 model (diff, diff hanger, hubs, drums, drive shafts, bolts etc)
Make sure the rear diff ratio matches the gearbox ratio.
I think you might need the crossmember for the gearbox aswell - can anybody clarify?
Easiest way is to find a complete 4x4 car to act as a donor then you know there won't be any bits missing.
a.
SuBaRiNo
Post by SuBaRiNo » Mon Apr 10, 2006 8:51 pm
I know witht the older models u have to change the fuel tank. I heard in an L series u don't have to cos the sedans already have the dipp for the diff.... wait for someone to confirm that though.
Dave
