				Best bang for buck ?
				Posted: Fri Dec 03, 2010 8:55 am
				by subarubrumby
				hey guy, got a 89 brumby, i converted it to rear wheel drive whats the best performance i can get for this without spending a lot of mular ? (money) hahaha got the exhaust system thats made a difference.
				Posted: Fri Dec 03, 2010 10:39 am
				by spike
				how did you convert itt rwd? Just remove front drive shafts??
Id say go webber maybe a hundred
Or go EJ, costs a lot more but a lot more bang, but then gbox goes boom
				Posted: Fri Dec 03, 2010 3:13 pm
				by Gannon
				Why make it RWD?
If you want a RWD ute get a commodore
				Posted: Fri Dec 03, 2010 9:27 pm
				The best ever bank for buck I reckon would be a WRX half cut + crossbred brake kit.  That'll cost a few $$$$ and time if you do it yourself but it would be WELL worth the mula and effort.  Plus it'd be AWD so it'd hand a lot better than a front or rear wheel drive.
If on a tight budget the weber would be the way to go as suggested.
You should be right with rear wheel drive, just keep an eye on the mount points as some here would say they won't hold with some flogging - but with the sort of flogging I've seen some EJ'd subi's cop in 4wd I reckon you'll be right.
				Posted: Sat Dec 04, 2010 1:15 pm
				by justin35
				The best running NA 1.8 subi ive been in was my mates stev,(and ive owned nearly 50 of these little rippers and done all types of mods .Now without turbo or supercharger mods this is what he done and it was relativly cheap and easy..He had the cam reground to a hillman hunter grind,shaved the heads 50tho each(which meant you have to elongate the inlet manifold holes as the heads were now closer together) electronic dizzy and bigger carb .you can go either twin carbs or the webber(i have run both and find them both very similar in performance)altho twins are hard to find in oz and expensive..you can find them in NZ really cheap tho)I wouldnt buy those 500$$ weber kits on ebay as you only need buy a webber carb sourced for about 100$$ and the adapter at sprints used to be about 50$$put you accell linkage from your carb straight onto the webber)bigger exhaust and of coarse he put a new set of rings and bearings thru it to..Now he was running gas most the time so if your running petrol you will need to run premiem fuel as it will have high compression,meaning it will ping if ran on standard fuel.But every person who drove this car car commented on how well it went and she never ran out of puff on sand hills...All these mods are cheap and easy done and im sure you will be happy with the results.But of coarse if youve got the time and money an ej conversion is a must for top performance
				Posted: Sat Dec 04, 2010 3:48 pm
				by TOONGA
				if you wanted to go whole hog
http://cgi.ebay.com/ebaymotors/JFS100-A ... rtsQ5fGear
I love how it says go kart
				Posted: Sat Dec 04, 2010 6:06 pm
				by spike
				justin35 wrote:whatever i wrote above =)
could have told us all that earlier =)
was that steve from rising sun??
so there are your options, or you could read what i wrote in my other post about performance EA82s
				Posted: Sat Dec 04, 2010 7:31 pm
				Suparoo wrote:Why make it RWD?
I was thinking about this today - you'd have the V8 option for this too
				Posted: Sat Dec 04, 2010 9:26 pm
				by justin35
				[quote="spike"]could have told us all that earlier =)
Steve b,aka my dads boss,,no another mate stev,who is also very handy with a spanner in his hand..
				Posted: Sat Dec 04, 2010 9:43 pm
				by spike
				ahh thought it was a typo =)
Anyway thanks for the details i might be able to use them on my engine.
How did he come up with the hillman cam grind??
				best bang for your buck?
				Posted: Sun Dec 05, 2010 12:13 am
				by ORX-18
				Buy a GT-R. id say i spent an easy 30k on motors alone and it still cant hold a candle to a GTR.
If its the EA you must have, then if its an 81, get ahold of kelford cams, chat to them about a cam and go get a webber carb. If its an 82, throw it in the bin and ref. step 1
				Posted: Sun Dec 05, 2010 8:20 am
				by sven '2'
I like your thinking...
But a lot of noise for 90 shp @
60,400 power turbine rpm
				Posted: Sun Dec 05, 2010 8:36 am
				by TOONGA
				sven '2' wrote:I like your thinking...
But a lot of noise for 90 shp @ 60,400 power turbine rpm
yes all that noise and 3000 rpm of PTO
imagine trying to use a clutch on it
				Posted: Thu Dec 09, 2010 1:51 pm
				by subarubrumby
				reason to convert to rear wheel is to skid it up !! hahah will post a video for all to see hahaa. cheers for the comments dudes.
