Advice please
Posted: Sat Nov 27, 2010 1:39 pm
by subaritza
if someone could give me an idea on mods for changing an outback 96 2.5 into a turbo or twin turbo,,,,
how much it could be done for changing ecu, any other comps in the car etc,, it would be muchly appreciated
Posted: Sat Nov 27, 2010 7:28 pm
by AlpineRaven
You'll need to change the clutch cable to hydraulic, engine - depends where you get it from, bellmark figure could be $1200 - $1600, loom & ECU from the half cut is required, re-wire etc so your looking at 2 grand under 3 grand.
Others here will tell you...
Posted: Sat Nov 27, 2010 8:14 pm
by Gannon
To do it properly, you are probably looking at over $5k
Hidden costs include upgraded brakes, radiator, fuel pump, wiring modification to name a few.
Are you planning on doing all the mechanical work yourself, or paying a mechanic?
Posted: Sun Nov 28, 2010 2:20 am
by seagull
Al from AM auto qld for the loom
Posted: Fri Dec 03, 2010 9:30 pm
seagull wrote:Al from AM auto qld for the loom
^ Ditto. He'll probably let you know what else is involved...
Posted: Sat Dec 04, 2010 8:13 am
by spike
1600 for the engine from wreckers, with a warrenty mind you.
6speed is another 1300 if im correct
Youd need fuel pump, computer, ancilleriers
BUT
Did the car come out with the twin turbo option??
the loom may be the same, just going on the fact its possible to change a twin to single turbo engine without many mods
Posted: Sat Dec 04, 2010 10:55 am
by sven '2'
Spike, I'll take 3 of your 6 speeds at $1,300!
There is a lot of info on here...search and you will find
Do not overlook a modified H6 conversion either.
Also has a look on RSLC.
As for for twins, avoid them like AIDS!
