engine rebuild questions
ok im in need of a new engine for the rally car
basically ive collected a load of bits that im hoping will bolt together with some mods and creat a mildly powered reliable beast
block: carb EA82, polished and lightened to take some weight of the front end
or i might use the MPFI block
heads: MPFI, ported polished and shaved (will need a modification to fit)
pistons: heres the main problem, i need pistons that will fit and be at least the same compression, my MPFI pistons are screwed so my options are to use the carb ones i have or go buy a good second hand set
intake: twin downdraughts i got off my brother, or maybe MPFi with cut down loom and all that so its put local and doesnt need to run the rest of the car.
any ideas?
will this word do we think?
any ideas?
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- brumbyrunner
yeah the MPFI could be a little difficult, when runnign the duel carbs its easy to shave the heads but when running a FI in take it has to be the same length
if i can get my self a mega squirt or other style ill try and put duel AFMs on it
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- brumbyrunner
TRE class
Cars and drivers must be road legal, an ej here wouldnt be legal and im not allowed to drive a turbo yet
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- brumbyrunner
- sven '2'
SA legislation prevents engine transplants where the original vehicle was not sold AUDM with that motor.brumbyrunner wrote:Why wouldn't an EJ18 be legal in SA?
For example: EA82T into a L-Series = OK as the RX was sold here. EJ (even a 18 ) was never a OME configuration so illegal
and as im only on my ps i wouldnt be allowed to run a turbo
However i am talking to somone about getting a EA82T as i get my full licenese early next year.
GETDIRTYCLOTHING
GETDIRTYCLOTHING
