ej22 from 97 Liberty into 91 Liberty
Helgram
Post by Helgram » Sat Oct 02, 2010 10:32 am
I have a 91 Liberty with a damaged EJ22. I have located an EJ22 from a 97 Liberty. Is it a straight swap or are their issues with engine management and/ or wiring?
Post by TOONGA » Sat Oct 02, 2010 10:42 am
are you sure it is an ej22 ?
if you just use the long block from the 97 liberty (as long as it is an EJ22) and use the engine managment stuff from the old engine (eg manifold injectors sensors from original motor) you won't have a problem
ps Im sure some one will disagree with what Im saying :)
Post by RSR 555 » Sat Oct 02, 2010 11:26 am
TOONGA wrote:are you sure it is an ej22 ?
I can if you want me to but I don't have all day to type it out :p
Helgram - it's best to use the long engine (rocker cover to rocker cover) with all the timing belt covers untouched.. and then use your inlet and exhaust manifolds and you won't have any troubles. Make sure you clean the radiator out and put in a new (tested) thermostat.
Parts required are..
Oil & filter
Coolant
Inlet and Exhaust gaskets
and not necessary but I'd also change the fuel filter :)
Post by TOONGA » Sat Oct 02, 2010 2:27 pm
RSR 555 wrote:I can if you want me to but I don't have all day to type it out :p
true... I have seen you type Image
and yes new gaskets are a must
Post by AlpineRaven » Sat Oct 02, 2010 4:39 pm
^^^^^ That what they said above, just remove the wireloom, SOME sensors (not all of them ie. temp, knock sensor etc) and use gen 1 wire loom on gen 2 engine.
Do a proper service ie. gaskets, seals, timing belt while its out because you wont know the history of the engine.
Helgram
Post by Helgram » Sun Oct 03, 2010 2:31 pm
Many thanks for your prompt replies. I will go for it.
