I think the GT could be better.
Posted: Thu Mar 25, 2010 8:34 pm
by SuBaRiNo
Im still thinking my 01 Forester GT is getting robbed of some power. Im pretty sure i still get better performance with my MAF sensor unpluged putting the ECU in limp mode.
Thoughs that have followed my other post about problems with my Forester will know the problems i was having before were caused by an extreamily dirty MAF sensor. The faults i was having are gone but i still think im getting robbed of some power.
With the MAF sensor unpluged i assume there are a few sensors the eCU simply ignores. Anyone know which ones?? The motor has done close to 200 thousand kms but the condition of the motor is fine.
Could the o2 sensors (there are 2 in this) be playing up a little since i think they have never ever been replaced? Or should i still be suspect of the MAF sensor.
Dave
Posted: Thu Mar 25, 2010 9:21 pm
by Gannon
The o2 sensor is ignored any time the turbo is making positive boost so i doubt it.
Im pretty sure that only the MAF is ignored when its unplugged
Posted: Thu Mar 25, 2010 11:17 pm
by AndrewT
stick a known good MAF on it. Paul's one from his B4 perhaps.
Posted: Fri Mar 26, 2010 12:26 am
by RSR 555
Or any sensors if they match?? I don't mind Dave :)
Posted: Fri Mar 26, 2010 10:39 am
by bobbyjimmy
Don't you have 3 sensors in the exhaust?
Air Fuel before the up-pipe, EGT just before the turbo and O2 after the cat?
Posted: Fri Mar 26, 2010 4:38 pm
by Subafury
Just chuck a boost controller on Dave. Will make it go a bit quicker. And spool a little quicker ;). I got a spare one if u wanna give it a go
Posted: Fri Mar 26, 2010 8:01 pm
by SuBaRiNo
I already got a manual boost controler in it.
I don't think so BobbyJimmy.
Dave
Posted: Fri Mar 26, 2010 8:19 pm
by Gannon
Subarino wrote:I don't think so BobbyJimmy.
Actually, he's right.
The front o2 sensor is at the Y join below the drivers side head, the EGT sensor is just before the turbo and the rear o2 sensor is at the rear of the dump pipe
Posted: Sun Mar 28, 2010 1:03 am
Supercharge it to remove the turbo lag :twisted: That'd be one setup to see! Otherwise make sure all the sensors are working well, the exhaust is flowing well and be contempt with what you've got... This is what I'm having trouble with - always looking for more power!!!
