Is it time? are EJ20T conversions - fully reliable?
Posted: Wed Mar 01, 2006 9:34 pm
OK , so heres the deal,
I have been thinking of doing the EJ20 conversion for a while now, and an opportunity has come up.
BUT...
after reading everyone's posts, the pros, the cons , in the end, is it worthwhile and is there a justifiable result? I am NOT cashed up, so , if go ahead with this, I want to use the donor parts as much as practical.
The end result MUST be a good , reliable car, which will be restored to being a NICE care once again.
So far, the main research to date has been on this, and the previous forums. The technique how to do it etc, but really sounds like a lot of effort, especially if you don't know exactly what to do, and getting information from here, there, this post and that post etc.
This is what I have come up with:
Car to convert: '88 AX7 XT Vortex, 4wd 5 speed EA82T ( basically an L series under the skin)
to EJ 20 T engined, with the donor being a:
Front cut EJ20T (either 90 Legacy or 95 WRX) to be decided.
From where I see it, there are 3 options
1. Running gear(engine, box, diff ECU and modded loom (all from donor front cut)
2. As above but using the EA82 gearbox with an adaptor plate
3. As 1, but with donor suspension, hubs brakes etc
So to do item 1
pull the running gear
Modify the ea82T cross-member (elongating the holes to suit the new mounts)
Modify the chassis rails ( somehow)
Modify the radiator mounting
Fit engine and box ( after replacing timing belts and hoses)
Modify the ea82 gearbox mount to suit new box
Have custom made CV driveshafts made, with ea82t hub ends and EJ20t splines (with distances recalculated to suit)
fit the clutch master cyl for hydraulic clutch
modify and fit doner pedal box to suit
Modify gearlever linkages
modify dump pipe and integrate into exaust system
transfer the diff center to 4.11 ( from 3.7)
shorten ( calculate new length) drive shaft (150mm approx from back end of gearbox)
strip loom and integrate into system ( errrrrrrr .... there seems to be no shaking of head with sheer terror emotion) 8O 8O 8O
somehow get the whole shebang running without it catching fire or killing it in the process.
item 2:
Somehow acquiring an appropriate adaptor plate
item 3:
Assuming this has somehow miraculously gone to plan so far, adapting the donor car front suspension, hubs, brakes and struts to suit the Vortex - which is basically an L series frame.
and converting the back end as well ( and shudders with utter terror)
I have no clue if the WRX suspension setup is the same or similar as the Legacy/ Liberty - and what the hell to do
What have I forgotten and overlooked, what are the main things to look out for, and someone tell me WHY am I thinking of doing this!
8O
Now that this is down in front of me, someone please talk me out of this before it goes too far and gets out of control.
I am sure I have seen a detailed conversion for this procedure, but I can't find it - probably just doing what my kids used to do and look straight past what I am looking for.
Experience to do this????? ( shudder again) not confident, but have removed / replaced engines, replaced clutches, brakes, suspension etc basic 12 v wiring. Handy , clewey... and can modify, weld and usually think my way out of tricky situations - but this SEEMS a little overwhelming - particularly the integration of the wireing.
...and 1 last thing, I need it legal in NSW
Reason to do even think about this - I dont know !! Someone give me one !!
BUT...
So to do item 1
item 2:
item 3:
