Fitting TD04 to EA82T
Posted: Sat Dec 26, 2009 10:41 pm
by H-top
With regards to water an oil lines, what mods are required to fit the turbo?
Cheers sam
Posted: Sat Dec 26, 2009 11:07 pm
by Gannon
Bugger all
The oil lines are the same, the water supply from the head is the same and the water return just has to go over the compressor outlet
I'll see if i can dig up some pics
Posted: Sun Dec 27, 2009 12:11 pm
by H-top
Fantastic, that would be great!
Posted: Mon Dec 28, 2009 11:43 am
by H-top
Find any pics?
cheers
sam
Posted: Mon Dec 28, 2009 12:15 pm
by Gannon
In this pic, you can see the water line (1/2 inch rubber heater hose) underneath the BOV
Here is another
Keep in mind that this setup is not ideal as an airlock can form and prevent convection of the water through the turbo after the engine is shut down.
Ideally, the water line should come straight out towards the tranny bellhousing and then underneath the compressor outlet. This will maintain a relatively straight path back to the thermostat
