Post
by GOD » Mon Aug 24, 2009 1:25 am
Easiest would be another EA82. Trouble is there is no such thing as a good EA82 (pipe down, you RX drivers).
If your current engine is carbied, all naturally aspirated EJ upgrades will require a similar amount of work. Turbos require a bit more in changing or modifying the engine crossmember.
My recommendation would be an EJ22 - they're cheap, easy to get parts for, easy to find wiring info on (very important for a conversion), and powerful enough to make an L series scary. The effort/benefit ratio is too high for any engine with less power (I know, I did an EJ18 first because like you, I wasn't looking to go fast. The EJ22 I have now is much better). Turbos and EJ25s are too expensive for the extra benefit they offer.
Converting to an auto will require mods to the tailshaft, an auto pedal box, and possibly some minor work on mounts. You'll also have to make sure that an auto transmission will fit in the trans tunnel.
My 2c.
Dane.
